front tire removal??? - Kawasaki ZX-10R.net
post #1 of 5 Old 04-27-2009, 11:21 AM Thread Starter
jblaze's Avatar
Images: 14
It's for a 2001 gsxr 750
I know it's a gsxr forum (I figure all front rim removal would be the same for metric bikes )but I'm trying to remove the front tire but no matter what I do the bolt does not want to move. Is the front axle bolt reverse thread or what special crap do I need to do to take this thing off?
jblaze is offline
post #2 of 5 Old 04-27-2009, 12:42 PM
leland's Avatar
LAIR
There is a hole on one side that needs a tool that will fit it. I have seen some people go find a bolt that will fit that hole, and then add a bolt onto its threads, so a wrench can hold it steady. I've never taken my front off before, but I'm guessing you might have to be spinning both sides of the axel at the same time???
leland is offline
post #3 of 5 Old 04-27-2009, 02:14 PM
rainking12's Avatar
Does it have pinch bolts? Might have to loosen those first.
rainking12 is offline
post #4 of 5 Old 04-27-2009, 09:39 PM
10rhawkdrvr's Avatar
Just changed the tire on the front of a friend of mine's 750. After a little advice from another friend, we left the front end off the stand and broke torque on the pinch bolts and on the the right side axle nut. We then put it on the front stand. To get the axle out we used a that would fit into the left side of the axle. Once the correct size bolt is found add nuts so that you can use it to twist and pull the axle out. The key for us was putting a little bit of tape on the bolt head so it would grip the axle as we twisted and pulled. Here is a page from the service manual:
REMOVAL AND DISASSEMBLY
• Remove the brake calipers.
• Loosen two axle pinch bolts 1 on the right front fork leg.
• Remove the front axle bolt 2.
• Remove the under cowling. (8-5)
• Raise the front wheel off the ground and support the motorcycle
with a jack or a wooden block.
• Loosen two axle pinch bolts 3 on the left front fork leg.
• Draw out the front axle and remove the front wheel.
NOTE:
After removing the front wheel, fit the calipers temporarily to the
original positions.
• Remove the collar 4.
Do not operate the brake lever while removing the calipers.
Do not carry out the work with the motorcycle resting
on the side-stand. Do not support the motorcycle with
the exhaust pipe. Make sure that the motorcycle is
supported securely.
10rhawkdrvr is offline
post #5 of 5 Old 04-27-2009, 09:45 PM Thread Starter
jblaze's Avatar
Images: 14
Thanks guys, I got it off by using a breaker bar.
jblaze is offline
Front sprocket nut removal? clausiam Performance and Tech 30 02-07-2008 01:51 PM
Front Fascia Removal AbramsM1 The ZX-10R 0 05-08-2007 01:56 PM
Front sprocket removal lespaul66 Performance and Tech 27 11-14-2006 10:24 AM
Front tire removal tbird The ZX-10R 9 04-29-2006 02:41 PM
brake rotor removal for tire change? JodyH Performance and Tech 11 01-21-2006 09:37 PM
