Front Sprocket too thin? - Kawasaki ZX-10R.net
post #1 of 23 Old 01-16-2008, 10:47 AM Thread Starter
afskypilot's Avatar
Greetings,
I installed a new 16t front sprocket and noticed that the chain had some side-to-side play in it. Is this a problem? Thanks in advance for the help.
afskypilot is offline
post #2 of 23 Old 01-16-2008, 11:03 AM
themightymezzo's Avatar
Did you get the right size chain/sprocket?
themightymezzo is offline
post #3 of 23 Old 01-16-2008, 12:21 PM
Big Daddy's Avatar
Images: 38
Originally Posted by afskypilot View Post
Greetings,
it can be.
When a chain/sprocket setup is purchased they should be the same config, ie 520, 525, 530 etc but even then there is a minor amount of side-side play(perhaps 1-2mm) but lets say we have a 520 sprocket with a 530 chain the side -side play or the gap may be 5mm which is not recommended.
Big Daddy is offline
post #4 of 23 Old 01-16-2008, 02:03 PM Thread Starter
afskypilot's Avatar
I just purchased the sprocket alone...didn't think about the chain. The side-to-side is really not that much. I'll do some measuring and see how much there is. What is the danger limit? Also, do you know what the stock size chain is?
post #5 of 23 Old 01-16-2008, 03:17 PM
Stock is 530, you probably got the wrong sprocket.
Josip Z is offline
post #6 of 23 Old 01-16-2008, 03:20 PM
silversv1k's Avatar
Images: 44
:iamwithst stock is 525
silversv1k is offline
post #7 of 23 Old 01-16-2008, 03:21 PM
Big Daddy's Avatar
Images: 38
mmmmmm no the OEM sprockets & chain from 04 to present are the 525 variety and typically owners will either stay with that size or use a 520.
post #8 of 23 Old 01-17-2008, 11:42 AM Thread Starter
afskypilot's Avatar
How much side-to-side is acceptable? What is the danger of having too much?
post #9 of 23 Old 01-17-2008, 04:56 PM
axo250's Avatar
Send a message via AIM to axo250
I'm not sure about limits but you shouldn't have but a smidgen. I'd say 2 millimeters or so. I'd take it back off and get a caliper to measure the width and then call the factory or look up to see the width on a 520 and 525 size sprocket. You definitely don't want to mix that with your chain size. If it is mixed up and you run it, you will wear your chain and sprocket out quicker plus risk breaking your chain after a while.
axo250 is offline
post #10 of 23 Old 01-17-2008, 05:13 PM
axo250's Avatar
http://www.gizmology.net/sprockets.htm
Here's a good site. Scroll down a bit and it tells the sprocket thickness...
For a 520: 0.227" = 5.9mm
For a 525: 0.284" = 7.2mm
Hope this helps!
axo250 is offline
Front sprocket grim Vendor Deals 4 05-07-2007 11:21 AM
thin head gasket,race cams, adj cam sprocket? mysticZX10 Performance and Tech 29 11-04-2006 10:25 PM
Sprocket change + Thin gasket/Intake cam. Too much? CountDokoo Performance and Tech 19 09-22-2006 01:35 PM
16t Front Sprocket mattfr12 The ZX-10R 10 07-24-2006 10:04 AM
front sprocket nut camarolongtube Performance and Tech 8 05-04-2006 11:17 PM
