Front sprocket nut removal? - Kawasaki ZX-10R.net
post #1 of 31 Old 04-14-2007, 07:21 AM Thread Starter
What length shaft do you need on a socket wrench to generate enough torque to get this stupid engine sprocket nut off?
This is standard threaded, not reverse right?
So far no luck getting it to budge. Going to the hardware store for an extension I guess.
clausiam is offline
post #2 of 31 Old 04-14-2007, 07:31 AM
B1GPAP1's Avatar
Send a message via Yahoo to B1GPAP1
You need to use an impact gun on it...
'06 ZX-10R: 16t, Ivan's TRE, K&N, Area P Exhaust (No Cat or Exhaust Valve), Dyno-Jet P.C., Michelin Pilot Powers, Puig Dub Bub(smoke), Clear Alternatives Smoked Lens, Comp Werkes Fender Eliminator, Roaring Toyz Arrow Bar Ends, LP Carbon Frame Sliders & Swingarm Sliders, Votex Oil Cap
_____________________________________________
BOMB TECHNICIAN...IF YOU SEE ME RUNNING,"YOU BETTER KEEP UP"
B1GPAP1 is offline
post #3 of 31 Old 04-14-2007, 07:31 AM
MIA Ex-Mod
Tread70's Avatar
It is a standard thread. I would imagine you need at least a 3ft cheater. I just used an impact and it zoomed right off.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #4 of 31 Old 04-14-2007, 08:12 AM
wash23's Avatar
18" x 1/2" drive breakover works fine for me. You still have to put some bacon on the end of it though.
wash23 is offline
post #5 of 31 Old 04-14-2007, 09:31 AM
BANNED
I had to run a ratchet strap around my rear tire connected to my suspension linkage and torque the strap down tight enough to where my rear wheel wouldn't move and use a 1/2 in breaker bar. Successful on two bikes now, it works damn good and I couldn't do it any other way. Or a good impact gun but I had a harbor freight model and it wouldn't budge it!
Suzuk1ki11a is offline
post #6 of 31 Old 04-14-2007, 09:36 AM
better have a good impact I had to put the big one on it and it didnt like it
69camaroandmore is offline
post #7 of 31 Old 04-14-2007, 09:39 AM
12RPilot's Avatar
Images: 11
My buddy borrowed a 1" impact wrench from his freind the truck mechanic. Then he cranked his air up to 170#. Put the socket on the sprocket, pulled the trigger and launched the bike through the drywall and broke several boards on the garage siding. Moral of the story: stick a board or something across the swingarm and through the back wheel.
12RPilot is offline
post #8 of 31 Old 04-14-2007, 09:48 AM
ZX10Rip's Avatar
Try putting your foot or having someone aply the rear brake with the chain still on.
ZX10Rip is offline
post #9 of 31 Old 04-14-2007, 09:53 AM
Big Daddy's Avatar
Images: 38
Originally Posted by ZX10Rip
Try putting your foot or having someone apply the rear brake with the chain still on.
yup most deffinately leave the chain intact before ya crack it loose.
Big Daddy is offline
post #10 of 31 Old 04-14-2007, 10:40 AM
Speed Freak
garth285's Avatar
if an impacter doesnt work then use a large 2 foot or so breaker bar and I have done this a few times but with the bike on the stand or the kickstand put it in gear roll the bike forwards until the gear stops it (this is so that theres no slack in the chain) and hold the rear brake at the same time and just crank on it, ya need some muscle to do this but it will sometimes work better than sitting there with an impactor or torching the nut to break it loose.
garth285 is offline
Front sprocket removal lespaul66 Performance and Tech 27 11-14-2006 09:24 AM
Front tire removal tbird The ZX-10R 9 04-29-2006 01:41 PM
Front Wheel Removal 05Ti10 Performance and Tech 13 01-02-2006 09:56 PM
Front wheel removal! NATOR The ZX-10R 19 09-15-2004 11:30 PM
front wheel removal...PITA?? MikeP The ZX-10R 18 08-19-2004 02:14 PM
