front sprocket nut - Kawasaki ZX-10R.net
post #1 of 9 Old 05-04-2006, 06:37 PM Thread Starter
front sprocket nut
I have tried everything i can think of to get this thing off. I have compleatley flatened the washer, used a torch, used a 3 ft breaker bar, an impact gun, and pentrating oil. this thing just wont turn is there anything elese i can use to get it off?
camarolongtube is offline
post #2 of 9 Old 05-04-2006, 06:41 PM
Post Whore
Older Guy's Avatar
Take it to the dealer and pay him the $35.00 to do it...
Older Guy is offline
post #3 of 9 Old 05-04-2006, 06:48 PM
Still here
ZX10Miami's Avatar
They can be deceptive.
They can look flattened, specially the obviously bent part, but still be holding at the base.
Happened to me on a Z750.
Went back with a socket that was a little bigger than the nut, and a mallet to flatten the retainer again. Off the nut came.
Would have sworn up and down I had flattened it the first time and by the looks of it before using socket.
Sarah Palin and friends can call it a snow machine all they want but Yamaha, Polaris and Bombardier plus the related magazines all seem to call them Snowmobiles.
Snow machines create snow on ski slopes. Just sayin'
ZX10Miami is offline
post #4 of 9 Old 05-04-2006, 07:15 PM
bluedevil's Avatar
Good advice miami.....
bluedevil is offline
post #5 of 9 Old 05-04-2006, 08:08 PM
NATOR's Avatar
Man i'll tell ya, had a bunch of friends over one night and we each took a crack at it with the breaker bar. No go. I hammered on it spit at it and called it every name in the book. Then after everyone left, I had a chat with it, put the breaker bar on and gave 'er one last heave.....off like butta.
BIKES IS GOOD.
NATOR is offline
post #6 of 9 Old 05-04-2006, 08:21 PM
busa41's Avatar
I changed mine to a 16 when I first bought bike.Came off fairly easy I just sat on bike and held rear brake.Then about a week ago I decided to change back to factory sprocket.I could not get it off without help.I held bike and brake plus stuck an axe handle through wheel then my buddy had to stand on pull handle and jump.It did finally break loose.But it was a bitch.I sure did not think I put it on that tight.
busa41 is offline
post #7 of 9 Old 05-04-2006, 08:33 PM
PostWhore
GuitarPlyr's Avatar
Send a message via Yahoo to GuitarPlyr
the more you ride it, the tighter it gets.....no way i could get it off by hand, but the impact had no problem whatsoever
John 8:24:
Therefore I said to you that you will die in your sins; for if you do not believe that I am He, you will die in your sins."
GuitarPlyr is offline
post #8 of 9 Old 05-04-2006, 10:01 PM
SpeedyCorky's Avatar
Send a message via AIM to SpeedyCorky
yea really.... 1 word:
air tools.
errr... 2 words..
- SpeedyCorky (stoppie addict) aka Charlie
* Support NASA!!! They are currently our only hope in getting off this rock. Help SETI find ET!!!
* The race is long, and in the end - it's only with yourself.
* In real life, the tortoise gets smoked.
SpeedyCorky is offline
post #9 of 9 Old 05-04-2006, 10:17 PM
Still here
ZX10Miami's Avatar
Should have mentioned- I was using an air gun.^^^^^
That is why I eventually rechecked the retaining washer.
Hard to see if the very base of it is truly off the bolt sometimes.
Maybe try a little penetrating lube to help it along if the retainer is truly flat.
Ok, my front sprocket was easy... -install with pics El Diablo Performance and Tech 122 04-02-2015 03:51 PM
need help with front sprocket guys! brianhknott Performance and Tech 18 04-20-2006 08:03 AM
Yes - another front sprocket question circusnuts The ZX-10R 16 09-07-2005 10:26 PM
Wow, 16T front sprocket on. ZXMustang The ZX-10R 29 09-04-2005 09:21 PM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
