front rotor problem of my zx10r - Kawasaki ZX-10R.net
post #1 of 5 Old 03-12-2008, 09:56 AM Thread Starter
plasticbaby's Avatar
today,i notice the round bushings will not hold the hub firmly to the disk,and there have obvious movements between the hub and disk.
i thinks the stock front rotors is semi floating rotors as my poor knowledge,it is not support to be like this,and it really did not like this before.
so i want ask your experts,is it dangerouse? or do i need change those front rotors immediately?thanks a lot!
plasticbaby is offline
post #2 of 5 Old 03-12-2008, 12:37 PM
FAF
Rent this space
There should be some movement , especially side to side.
FAF is offline
post #3 of 5 Old 03-13-2008, 12:50 PM Thread Starter
thank you very much!!!
post #4 of 5 Old 03-13-2008, 01:08 PM
Big Daddy's Avatar
Images: 38
As FAF states there should be side to side movement although slight as the buttons allow this so the rotors will float or move if needed.
Big Daddy is offline
post #5 of 5 Old 03-15-2008, 09:39 AM Thread Starter
after your guys explain,i feel safe to ride my 10r now,thanks again:)
Front rotor bolts!! bodymanruss518 Wanted: Buy or Trade 7 02-21-2008 10:01 PM
Tires/Front Rotor/Rear Rim dray4life Parts, Gear and Accessories 3 08-08-2007 02:34 PM
Galfer Waiver Rotor vs. Braking Waive Rotor zx-10r203 Performance and Tech 19 07-17-2007 07:47 AM
Wanted: 2002 Zx9R Front Right Brake Rotor Notch Wanted: Buy or Trade 4 10-18-2006 12:14 AM
Front rotor suggestions Ground Zero Performance and Tech 4 09-18-2005 10:41 PM
