Front end wants to tuck?? - Kawasaki ZX-10R.net
post #1 of 39 Old 02-08-2010, 10:25 AM Thread Starter
Kwakkid's Avatar
Hi guys, i've previously owned a 2008 zx10 so know how the bike rides, but can't get my new one to feel stable at low speeds. Feels like the front wants to fold in/ is oversteering in a big way on slow turns and roundabouts etc. I'm having to really countersteer to keep it on line. I've had a good 'play around' with the front susp settings (i'm not pro but have a good understanding) but nothing seems to cure this feeling. Anyone else had what i've described, and if so what did you do?? My first 08 zx10 never felt like this!!
Kwakkid is offline
post #2 of 39 Old 02-08-2010, 10:30 AM
rkwaki's Avatar
What is your air pressure set at?
rkwaki is offline
post #3 of 39 Old 02-08-2010, 10:48 AM
Might be a dumb question..but did you buy the bike new? If not, were there any geometrical changes made by the previous owner?
cdill35 is offline
post #4 of 39 Old 02-08-2010, 10:52 AM Thread Starter
Kwakkid's Avatar
As per the handbook. 42/36. And i've checked them. Always run at the reccomended pressures on Corsa 3's and 2CT's with no probs
Kwakkid is offline
post #5 of 39 Old 02-08-2010, 11:00 AM Thread Starter
Kwakkid's Avatar
Not a dumb question at all. I'm the 2nd owner and checked every single thing was stock the day i had it delivered. Previous guy didn't touch a thing.
Kwakkid is offline
post #6 of 39 Old 02-08-2010, 11:06 AM Thread Starter
Kwakkid's Avatar
Am the 2nd owner but checked the bike the day i had it delivered to make sure it was 100% stock.
Kwakkid is offline
post #7 of 39 Old 02-08-2010, 11:16 AM
BANNED
ZX10Rracer's Avatar
PSI is too high no matter what tire your running! lower it 5 PSI less depending on the tire brand, I run 2CT's on the street and run 31PSI front for hard riding.
Next how raised are your forks in the triples from the bottom of the cap {just the gold}i.e, how lowered is the front}} next what do you have your rebound set at? if it's too stiff you could be getting what is called "packing" that will make your font end tuck!
ZX10Rracer is offline
post #8 of 39 Old 02-08-2010, 11:19 AM
rkwaki's Avatar
That's where I was going with air pressure. I run even lower than that 29F 27R.
I thik before anything can be recommended please post up your current settings as well as weight and you can probably get some better feedback.
If you have nothing nice to say - "Shut the [email protected] up"
rkwaki is offline
post #9 of 39 Old 02-08-2010, 11:27 AM
daveb4c's Avatar
I had the same problem on Corsa 3's and it was an air pressure issue as other mentioned might be the case.
I set the front to 31 and it felt much better.
How many miles are on the tires?
daveb4c is offline
post #10 of 39 Old 02-08-2010, 11:30 AM Thread Starter
Kwakkid's Avatar
Forks are set at standard height. I've not touched them (few mm showing) My rebound is 8 clicks out from fully seated and my compression is also standard. When you say too stiff, i assume you mean lack of damping so the forks are coming up too quick?
Kwakkid is offline
Front end headshake hellsrazor The ZX-10R 15 08-08-2009 05:03 PM
WTB- front tire hugger, RAM AIR, FRONT END swing lo Wanted: Buy or Trade 2 07-10-2007 08:30 AM
06 10 and 05 10 front end? are they the same? jblaze Performance and Tech 3 02-14-2006 06:54 PM
Front end falling off evander The ZX-10R 3 09-22-2004 06:10 PM
Leather pants that don't tuck in ? hayabusa57 The ZX-10R 1 05-15-2004 08:30 PM
