is it the front brakes? - Kawasaki ZX-10R.net
post #1 of 15 Old 04-11-2011, 02:01 PM Thread Starter
Btrain87's Avatar
ok so i just completely upgraded my 04 10r with the front zx-14 calipers, galfer gp ss lines, and a zx-14 master. as for the rear, just put some speigler ss lines on it. today was the first time i got to take my baby out for a ride. it felt amazing honestly to finally get back out there. so as i was riding, i ran into a spot where i had to brake abruptly and when i pulled the lever i was braking but it didn't feel like it was biting super hard. so i go to use the rear brake and that shit locks up in miliseconds and my rear is swerving all over the place so i let up and then re apply, same thing happens lol. this happened to me twice today actually. i was able to get out of the situations clearly, but why didn't the front brakes bite. obviously the rear brake is much more resposnive because i don't think i ever locked up the rear wheel twice in one ride. when i bled the front i didn't see any air bubbles but the only thing i can think of is that after i was all done, i noticed my line was touching the rim. with the bleeder nipple closed, i loosened the screw to re-adjust for a split second, did that let air back into the system? do i need to re-bleed or is it possible that the mc i have is no bueno? i can always count on my guru's! TIA
Btrain87 is offline
post #2 of 15 Old 04-11-2011, 02:38 PM
SkyDork's Avatar
What pads are you running in the front? Are they new or did they come in the calipers you bought? The setup you describe should be close to locking the front with anything more than 2 fingers on the lever. It's just that good of a setup. What you're describing on the front sounds like the pads are poor or not seated to the rotors yet.
#WordCrimes
SkyDork is offline
post #3 of 15 Old 04-11-2011, 05:14 PM Thread Starter
Btrain87's Avatar
Yeah that's what i've been told and I can see how great the back breaks got from just the ss lines. I kept the stock pads in the calipers because they only had 1100 miles on them. I did noticed all new lines on the rotors, how long should it take to seat in?
Btrain87 is offline
post #4 of 15 Old 04-11-2011, 06:16 PM
wheeliest's Avatar
Send a message via AIM to wheeliest
air still in the lines...
wheeliest is offline
post #5 of 15 Old 04-11-2011, 07:16 PM
Judge Dredd Mod
mr_honez's Avatar
I'd say it is a combination of the two, but mostly air is still in there somewhere. I'd rebleed them and see how it feels.
BURNOUT.....
mr_honez is offline
post #6 of 15 Old 04-11-2011, 07:32 PM
Gen 5 Now!!
08zx10rny's Avatar
is the lever firm or does it go most of the wayto the handlebar?? if goes pretty far probably air in the lines, if its firm the pads arent bedded in yet. give them maybe 50-100 miles.
08zx10rny is offline
post #7 of 15 Old 04-11-2011, 08:00 PM Thread Starter
Btrain87's Avatar
I have yana shikki levers and I the brake setting lever I use is 5 so it only come with in 2 inches of the handle bar, that didn't seems to bad but I just put it to 1 and with a strong grip I can get it to like a 1/2 inch from the grip so looks like we solved the problem here lol ill re-bleed and report back
Btrain87 is offline
post #8 of 15 Old 04-11-2011, 08:39 PM
wheeliest's Avatar
u can bleed the banjo bolts and also tapping everything with a wrench will free up air bubble..
post #9 of 15 Old 04-11-2011, 08:56 PM
09zx10miami's Avatar
09zx10miami is offline
post #10 of 15 Old 04-12-2011, 07:08 PM Thread Starter
Btrain87's Avatar
Ok so I rebled the system and there is definitely air in the system. In fact, there was a considerable amount. It does not want to leave though. I want to drain the entire system And start from scratch. I have a few questions though; first, does it matter the order I bleed the system eg calipers before master or visa versa? Second, can I re use the fluid that comes out of the system?
Btrain87 is offline
Front brakes ? 10RDan The ZX-10R 7 07-23-2010 04:30 PM
new old front end and new brakes kawboy10 Pictures and Videos 13 12-30-2009 07:34 AM
06-07 front brakes slamdcoop Performance and Tech 8 07-29-2009 04:22 PM
Front Brakes?? Stwcar The ZX-10R 8 04-26-2009 11:59 PM
Front brakes? zxerboy22 The ZX-10R 3 02-20-2007 03:40 PM
