Gen 2: 2006-2007 Front brake system replacement, master+calipers. (2007 zx10r) - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Bottoms-Up
post #1 of 6 Old 10-13-2019, 11:50 AM Thread Starter
Red face Front brake system replacement, master+calipers. (2007 zx10r)
Hello, what do folks recommend for a bolt-on full front brake system replacement for a 2007 zx10r (including model/year for the parts)? (better braking and low maintenance + bolt on)
Reason: my 2007 zx10r front brake system recently started to get extremely soft when bike sits for a few days and it's time to treat myself to a new system after 12 years instead of debugging the old crufty one.
(I do not see any evidence of leaks and think this might as well be a good time to upgrade from stock calipers and master and just redo the entire system now that the bike is holy cow 12 years old! :) )
hicyde is offline
post #2 of 6 Old 10-13-2019, 12:51 PM
zx racer's Avatar
Most just keep the stock mc and ditch the calipers for pair of nissin calipers from the later model zx6r, zx14. Big difference in braking and there a direct fit i also have a pair fs if interested.
https://r.tapatalk.com/shareLink/top...k _source=app
Nissin Caliper
Sent from my SCH-I545 using Tapatalk
zx racer is offline
post #3 of 6 Old 10-13-2019, 02:04 PM
michael4012's Avatar
I agree with the above, later 6 or 14 calipers, braided lines and good pads. Huge Huge difference.
michael4012 is offline
post #4 of 6 Old 10-13-2019, 05:23 PM
GreenOne's Avatar
For street and slow-moderate track, there is absolutely nothing wrong with the stock setup mc and calipers if it`s working as it should. Get a rebuild kit instead of bying something else that may need service. Throw in a pair of braided lines and new good pads. All you need. My opinion anyway.
GreenOne is offline
post #5 of 6 Old 10-13-2019, 06:07 PM
Bottoms-Up's Avatar
Lots of threads on this, but.....
Here's my set up on my gen 2. I think it's about
everything I can do before upping the budget.
With the following mods I can now get through
a 20 minute track session with no fade.
later model rotors 300mm -> 310mm
converted them to full floating
Nissin Calipers with 5mm spacers
Vesrah pads
braided lines
Motul fluid
Stock Nissin MC
Paulo Mav likes this.
Bottoms-Up is offline
post #6 of 6 Old 10-17-2019, 11:32 AM
Kone35's Avatar
Stock master....or 05 up R1 master, braided lines, 12 cbr 1000r monobloc calipers, pads of your choice. Night and day difference bro. I run the R1 master. The 10r master is good with a clean, rebuild, and Teflon tape on the nipple. Just make sure that you bleed the crap out of it. Don't know why, but the stock mc traps a lot of air.
Kone35 is offline
Tags
brake calipers
