Gen 4: 2011-2015 front brake problem - Kawasaki ZX-10R.net
 5Likes
post #1 of 12 Old 05-19-2015, 09:41 AM Thread Starter
tone.r's Avatar
front brake problem
Hey guys im working on a friends gen4, his front brakes doing some crazy stuff. If i grab the lever it feels real good, then theres no lever without pumping it 1 or 2 times
1st thing i seen was that he must have mixed brake fluid because it looked like a gel in the reservoir, so i flushed out and changed brake fluid, then i replaced the diaphragm it was jacked up.
2nd thing i rebuilt the master cylinder
3rd thing breed the brakes about 5 times, with a pump and manually
The brakes are not leaking fluid anyplace, I had one of my friends tell me it must be air still in the lines, I think its something else at this point any suggestions, HELP
tone.r is offline
post #2 of 12 Old 05-19-2015, 09:57 AM
SkyDork's Avatar
If brake fluid was mixed, you might have to do a complete disassembly and cleaning of the calipers. DOT 3, 4, and 5.1 are glycol based fluids and are relatively safe to mix. DOT 5 is pure silicone and incompatible with anything else. If he added DOT 5 in with the regular stuff that came with the bike, who knows what kind of crud is in the calipers.
The bleed technique is to start at the master cylinder and bleed it there first. Then move onto the calipers. The pump works great for roughing it in, but nothing beats a hand bleed to make sure all the air is removed. It's also helpful to strap the brake lever overnight with pressure before a final hand bleed the next day.
#WordCrimes
SkyDork is offline
post #3 of 12 Old 05-19-2015, 12:18 PM
Was just popping in to chime in with this. This does wonders.
ZX10RArcher is offline
post #4 of 12 Old 05-19-2015, 12:34 PM
White Fang's Avatar
After all this you had best rebuild the whole system and replace all seals. If you are truly qualified. This bike needs all the brakes it can get. Don't mess around with the brakes.
White Fang is offline
post #5 of 12 Old 05-19-2015, 12:35 PM
White Fang's Avatar
Yes it does but you had best find out what the problem with the system is first.
post #6 of 12 Old 05-19-2015, 02:37 PM Thread Starter
tone.r's Avatar
I started with the master first, I'm going to try that technique, but after talk to another member he think it might be the rotor and it could be because the bike owner did bend the front rim pretty bad.
tone.r is offline
post #7 of 12 Old 05-19-2015, 03:10 PM
dricked's Avatar
Well that's valuable information that would change the answer on where to start looking...
White Fang likes this.
dricked is offline
post #8 of 12 Old 05-19-2015, 09:30 PM Thread Starter
tone.r's Avatar
I talked to the bike owner today he told me he was hitting the disk with a rubber hammer, Im pissed he left out that valuable bit of info, I dicked around with this for about 12 hours
tone.r is offline
post #9 of 12 Old 05-19-2015, 11:14 PM
White Fang's Avatar
You are not gonna be able to fix the bike going about it like that. Dang, can't you all find a used rotor or something?
post #10 of 12 Old 05-20-2015, 07:43 AM
Niner1000RR's Avatar
If all of the above didn't work, try cracking it at the banjo's on the calipers (obviously with pressure on the lever).
I've had issues in the past where air gets caught at the banjo and that seemed to be the only way to solve it...
Niner1000RR is offline
Gen 1: FS: Brake pads, front axle, CRG shorty lever (brake), stock calipers (free) SecondGen7 Parts, Gear and Accessories 8 09-24-2013 11:38 AM
gen1 brake rotors calipers and front brake master cylinder BUGSY_MONTANA410 Parts, Gear and Accessories 3 06-13-2013 02:44 PM
Gen 3: Stock Front Brake Calipers With Brake Pads $100 Shipped 1fast10r619 Parts, Gear and Accessories 0 04-30-2013 12:50 AM
3rd Generation front brake problem readeth The ZX-10R 13 05-09-2009 08:57 AM
Front brake problem. Any ideas ? ninja9r Performance and Tech 19 04-23-2005 02:05 AM
