Front brake help - Kawasaki ZX-10R.net
post #1 of 9 Old 04-07-2009, 01:52 PM Thread Starter
Front brake help
I looked at all the threads for this, but cant find an answer.
My front brakes are surging when I use them. I cleaned them, by exposing as much of the pistons as I could get to, changed out the brake fluid, and bled them a few times. Then I zip tied the lever down overnight, and bled them again.
This will last a week or two, then I get the surging again.
Does anyone know how to fix this. I really dont want to have to rebuild the calipers, but if thats the only way then....
I dont want to upgrade the calipers and brakes as I was happy with the braking power on the factory ones.
Any ideas?
(edit: the bike is an 05)
spanky3780 is offline
post #2 of 9 Old 04-07-2009, 02:00 PM
kawi1000's Avatar
Images: 26
Unfortunately 04-07 10R has awfull brakes a swap with CBR, R1, ZX14 and Nissin ZX6R is the best mod for your bike like night and day. Either swap the Master cylinder with brembo but the caliper really makes a big difference with stock MC of the 06-07.
kawi1000 is offline
post #3 of 9 Old 04-07-2009, 04:15 PM
BackMarker's Avatar
Sounds like a bent rotor............
Spin the front wheel while holding to straight edge close to the rotor and check it for run out.
Check in the manual.......it will tell you how to do it.
WERA Expert #760
'10 N.E./Mid-A Hwt. Senior Superbike Champ
'09 N.E. "A" Superstock Champ
'09 Senior Superbike Champ
www.sichertengraving.com - www.Karns-performance.com - www.Absolutesignshop.com - www.Untamedvelocity.com - www.keystonegenerators.com
Vortex - Hotbodies - Scorpion Helmets - LP Racing - Vesrah - Pitbull
BackMarker is offline
post #4 of 9 Old 04-07-2009, 04:28 PM Thread Starter
I checked the rotor and it is still true. Its at the caliper level, when I bleed it, it goes away. I was thinking maybe just rebuild the calipers, but am trying to see if I can get away with something less involved.
post #5 of 9 Old 04-07-2009, 05:02 PM
kawi1000's Avatar
Images: 26
Ok 04-05 bike don't have the bleeding bolt on the master cylinder you probably still have air on the master cylinder. Some of the member replace the master cylinder with zx6r or crack open a little bit the banjo bolt with dirty rag and squeeze let the air out. I hope that helps.
kawi1000 is offline
post #6 of 9 Old 04-07-2009, 05:11 PM
kawi1000's Avatar
Images: 26
you need to invest on this if you like the stock setup.
kawi1000 is offline
post #7 of 9 Old 04-18-2009, 08:42 PM
lethal_whisper's Avatar
Is there any particular year range to stay in with these? Around 05-09 or does it matter?
lethal_whisper is offline
post #8 of 9 Old 04-18-2009, 09:36 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
you can always upgrade :)
I have a CBR caliper and Brembo 19x18 for sale :)
Lucky10R is offline
post #9 of 9 Old 04-19-2009, 11:52 AM
Where'd the boobs go?
kawdude636's Avatar
how much for the brembo shipped to 49029?
kawdude636 is offline
Front Brake issues on '07 ZX-10R evoracer518 Performance and Tech 7 07-08-2008 08:47 AM
Front Brake Calipers??? ninjasuz Performance and Tech 24 02-15-2008 02:16 AM
FS: 04/05 Front Brake Setup. NYC_ZX10 Parts, Gear and Accessories 6 11-26-2007 02:50 PM
'05 ZX-10R Front Brake M/C IcePick06 Parts, Gear and Accessories 0 01-25-2006 05:20 AM
FRONT BRAKE! trackaddict Performance and Tech 11 09-08-2004 08:25 PM
