Front Brake Clips ???? - Kawasaki ZX-10R.net
post #1 of 11 Old 04-14-2006, 06:26 PM Thread Starter
mach_man_187's Avatar
Question Front Brake Clips ????
I have had 2 of the clips that attach to the front brake pads come loose and rattle....Anyone know why this happens? How do I fix it???????
If you're not living on the edge, your taking up too much space!
mach_man_187 is offline
post #2 of 11 Old 04-14-2006, 06:30 PM
bluedevil's Avatar
not sure...I know the rear brake has a very very small hitch clip....maybe related as I had to replace one.
bluedevil is offline
post #3 of 11 Old 04-14-2006, 07:35 PM
rocketracermike's Avatar
i did my front brakes last month. they snap off and snap on. havn't had a probem with them.
rocketracermike is offline
post #4 of 11 Old 04-14-2006, 07:55 PM Thread Starter
Could I have bent them when I took them off and just need to tweak them???? I rebent the 2 that were loose, and they seem fine now. I just wondered if I screwed something up or what the deal was.
post #5 of 11 Old 04-14-2006, 08:08 PM
they should be flush with the pads. you can also go to a parts store and pick up a tube of. i can't think of the name, but it's made for cars brake pads to stop the chatter noise. just spread a thin layer on back of the pads and then snap on the clip.
post #6 of 11 Old 04-14-2006, 08:13 PM
bluedevil's Avatar
think you are talking about this stuff I bought from Kragen Auto store:
from CRC...Named Disc Brake Quite...4oz bottle...in red liquid..UPC code:
0 78254 05016 4
post #7 of 11 Old 04-14-2006, 08:22 PM
thats the stuff. it do work on stopping the noise
post #8 of 11 Old 04-14-2006, 08:53 PM
OMG Look at that squid!!
trackaddict's Avatar
Images: 51
If you are refering to the "heatsink" discs attached to the back of each brake pad, REMOVE THEM. They add to the shitty brake lever feel big time... I've run w/o them for a couple years now with no side affects.
Because wheelie!!!
17' Honda 1000RR SP - 08' Hypermotard 1100s
16' ZX10R - SOLD
14' Ducati Monster 1200S - SOLD
13' RSV4-R - SOLD
My ZX10R's 11' - 08' - 07' - 05' - 04' - ALL SOLD
Miss my Black 04' the most!
Never enough money, never enough time!
trackaddict is offline
post #9 of 11 Old 04-15-2006, 07:11 AM
Post Whore
Sgtusmc96's Avatar
Yep removed mine also.
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #10 of 11 Old 04-15-2006, 10:59 AM
sneaky's Avatar
Yep removed mine and the anti rattle clips....
sneaky is offline
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
Win a set of Galfer Brake Lines! Front & Rear!!-WINNER ANNOUNCED! RichTJ99 The ZX-10R 472 11-10-2005 01:37 PM
Weak front brake cyclops24 Performance and Tech 6 07-24-2005 09:56 AM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 12:29 PM
