Gen 4: 2011-2015 Front Axle Removal - Kawasaki ZX-10R.net
post #1 of 5 Old 08-29-2012, 10:37 AM Thread Starter
Front Axle Removal
Please don't make fun of me for a dumb question...
My 2012 Gen 4 is in need of new rubber. I want to remove the wheels myself to have new donuts spooned on at the dealer to save a few bucks. I look at the front axle and was surprised to see a 22mm hex on both sides. My old bike had a 19mm hex on one side and a 32mm hex bolt on the other side. I need to get me a 22mm hex bit, but do I need two? I checked the service manual and it looks like I need only one, but it is not that specific. Is it OK to rely on the pinch bolts to hold the opposite end of the axle?
Velox is offline
post #2 of 5 Old 08-29-2012, 03:04 PM
WildB302's Avatar
I'm sure if you leave the pinch bolts tight, you can loosen the other side to remove it. That's how I do my gen 1.
08 race cam(108/103), 08 retainers, polished exhaust ports, milled head(.010), .45HG, short velocity stacks, removed sec, bmc filter, full Akra Evo cut 5in, pc3., ign module w/rev xtend to 13,500., Lots of 520 sprckts, vortex rearsets (gp shift), pazzo levers, galfer lines, ZX14 calipers, shorai batt, carbon frnt fender, gpr, puig screen, gilles chain adjs., 1/5 throttle, Kleen air mod, Braking rotors, O.Z. wheels, 403lbs full fuel
http://www.youtube.com/user/TheWildb302/videos
WildB302 is offline
post #3 of 5 Old 08-29-2012, 03:16 PM
or10r's Avatar
I only use one and I loosen my pinch bolts first. Its always worked fine for me. I guessin your pinch bolts would hold it but Id invest in the proper wrench. BTW did you check the factory tool kit??
or10r is offline
post #4 of 5 Old 08-29-2012, 04:16 PM
Squid wannabe
rafa's Avatar
On what they said.
I have a 4th gen and you leave the pinch bolts holding the axle while you loose one side.
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline
post #5 of 5 Old 08-29-2012, 06:50 PM Thread Starter
ThankS for clearing that up for me.
Velox is offline
Gen 1: WTB: 04-05 front axle ke2012 Wanted: Buy or Trade 1 02-15-2011 04:28 PM
Looking For 08 front Axle 9R to 10R Wanted: Buy or Trade 5 09-21-2009 07:53 PM
Need 06 awingarm axle removal tool. SAkI Wanted: Buy or Trade 1 10-03-2008 06:06 PM
04-05 Front Axle walkthisway21 Wanted: Buy or Trade 0 05-22-2008 04:25 PM
Need 06-07 Front Axle!!!!! garth285 Wanted: Buy or Trade 0 05-21-2008 09:52 PM
