Front axle nut sizes? - Kawasaki ZX-10R.net
post #1 of 7 Old 05-10-2007, 05:53 PM Thread Starter
So Im trying to get everything I need for the bike to take the front tire off and I dont know what size the nutz are....Looks like the right side is smaller size than the left. Its a 2006, can anyone tell me so I can buy a socket and wrench tonight! THANKS
jessiah1 is offline
post #2 of 7 Old 05-10-2007, 07:19 PM
zx10x2's Avatar
Images: 19
Send a message via Yahoo to zx10x2
only the left side screws off. then you slide it out the right side. Its a 30mm.
- 90 Mustang Coupe - 578 hp Grocery Getter
- 06 ZX-10 no mods - I love it
- 10 F250 Crew Cab
- 08 F-450 Crew Cab
I HAD A HANDLE ON LIFE, BUT IT BROKE OFF
zx10x2 is offline
post #3 of 7 Old 05-10-2007, 08:32 PM Thread Starter
Thanks, got what I need. Also got a 27 mm wrench to hold the other nut.
jessiah1 is offline
post #4 of 7 Old 05-12-2007, 09:24 PM
Anyone have the torque specs on:
the front axle nuts
the four allen head bolts that clamp the axle
the allen head bolts on the brake calipers?
cbtenr is offline
post #5 of 7 Old 05-13-2007, 07:33 AM Thread Starter
the front axle nuts
You only tighten the left side axle nut while you hold the right side with a wrench, 94 ft lbs
Allen fork clamp bolts to 15 ft lbs
Calipers do not have a torque setting in the service man. I just made them snug.
jessiah1 is offline
post #6 of 7 Old 05-13-2007, 11:39 AM
coach's Avatar
Which calpiers are you talking about. All the bolts have torque figures.
Not enough room here to list everything.
coach is offline
post #7 of 7 Old 05-13-2007, 08:23 PM Thread Starter
Yea, my bad. I forgot to look them up in the manual. I was only using the wheel removal section. The mounting bolts for the caliper are 25 ft lb, but I just snugged em.
jessiah1 is offline
04/05 front axle wanted `cactus grunt Wanted: Buy or Trade 3 09-26-2006 09:15 PM
Front Axle W/ Spacers treyzx10r Parts, Gear and Accessories 3 08-18-2006 09:29 PM
Rear and front axle dia ??? lespaul66 Performance and Tech 2 03-01-2006 02:34 PM
Front axle nut size? Rattler Performance and Tech 2 02-02-2005 05:20 PM
Front Axle Nut Size? dnwhoop02 Performance and Tech 13 09-04-2004 12:34 AM
