Front axle bolt size 29mm or 30mm - Kawasaki ZX-10R.net
post #1 of 5 Old 03-24-2008, 03:54 PM Thread Starter
limegreenbloodz's Avatar
Hi,anyone knows the size of the front wheel axle bolt on the left side(shifter side).need to buy the right socket today bc don't want to go back to the store.thank you
limegreenbloodz is offline
post #2 of 5 Old 03-24-2008, 07:07 PM Thread Starter
found it...well I guessed and took a chance : needed 27mm socket for right side and a 30mm socket for left.
post #3 of 5 Old 03-24-2008, 07:09 PM
ninja44's Avatar
You just need to loosen the 27 mm nut (clutch side). You can return the 30 mm as only one side is needed to turn to remove the axle.
ninja44 is offline
post #4 of 5 Old 03-24-2008, 07:31 PM
Andy's Avatar
Images: 25
You're gonna need a 22mm allen head for that '08, they changed them this year. The wrench and the 3/4 to 1/2 adapter that I needed put me back $43. :headshake just a fyi
Andy is offline
post #5 of 5 Old 03-24-2008, 07:47 PM
ninja44's Avatar
What's the 22mm allen head for? I'm assuming the OP has a pre 08 bike. I'm pretty sure I have the tools needed for the 08.
ninja44 is offline
front and rear axle nut size? Wind Draft The ZX-10R 3 08-31-2007 10:55 AM
Axle bolt Size? Gang Green The ZX-10R 7 06-30-2007 12:59 PM
to remove front axle clamp bolt kuzco The ZX-10R 10 04-01-2005 01:28 AM
Front axle nut size? Rattler Performance and Tech 2 02-02-2005 06:20 PM
Front Axle Nut Size? dnwhoop02 Performance and Tech 13 09-04-2004 01:34 AM
