Frame slider installation - Kawasaki ZX-10R.net
post #1 of 7 Old 07-17-2005, 08:21 PM Thread Starter
Question Frame slider installation
I just purchased a pair of no cut shogun frame sliders. It looks like they should be easy to install. Never worked on my bike before. Can anyone tell me the tools I need ?
rgpoppop is offline
post #2 of 7 Old 07-17-2005, 09:08 PM
circusnuts's Avatar
It was so long ago I don't recall the sockets required (can find a lot of this on the site search), but I can recommend that you follow the torque specs on all of the bolts that you disturb (particularly that top engine mount bolt).
I think it's something like 33 or 38 ft lb.
For the ZX10 manual (torque specs)
https://zx-10r.net/forum/showthread.php?t=5552
Dress for the slide & not the ride
circusnuts is offline
post #3 of 7 Old 07-18-2005, 12:25 AM
dogbone's Avatar
I can testify to the importance of obeying torque specs....thank god for warranty's and leinent dealerships.....
dogbone is offline
post #4 of 7 Old 07-18-2005, 12:39 AM
Post Whore
El Diablo's Avatar
Moved to tech...
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #5 of 7 Old 07-18-2005, 12:39 AM
Post Whore
El Diablo's Avatar
Damn! You done that overtightening a bolt?? What were you using? A ten foot cheater bar?
El Diablo
post #6 of 7 Old 07-18-2005, 11:59 AM
champ91's Avatar
Venturing to guess but looks like the slider was not mounted to an engine mount but rather one of the bracket locations. The Torque spec on an M10 bolt would be 32 ft pounds. IF you broke this while torquing then you a. either have a torque wrench that is seriously out of wack b. your not using a torque wrench and are a big boy or c. you crashed and this is the result of mounting to a non rigid location
NESBA #456 Intermediate
champ91 is offline
post #7 of 7 Old 07-18-2005, 08:13 PM
dogbone's Avatar
Have a torque wrench, but its not very accurate. I snugged it and then gave it another 1/8 turn +/- to make sure it wouldn't come loose. I have a feeling the vibration from the engine combined with the overtightened bolt, and possibly a weak casting, caused the fractures. Wasn't a crash though....Not even a tip over....Also, its not in a mount in the block per say, but rather into the brackets. It was my mistake on installation, but as I cut the fairing, I have to live with it......Once I fighter the 10, it'll be running mostly naked, so I'll change the mount to the correct area.....
dogbone is offline
Frame slider installation ??? johnnyb-21 The ZX-10R 21 05-03-2006 10:33 AM
Frame slider installation rgpoppop Performance and Tech 0 07-17-2005 07:38 PM
Frame Slider Installation racerman Performance and Tech 16 05-10-2005 08:01 PM
Frame Slider Blow-out flatout Vendors deals 2 02-17-2005 11:37 AM
reputable place to buy frame slider kuzco The ZX-10R 1 06-25-2004 04:42 PM
