Frame guys Help!!!! - Kawasaki ZX-10R.net
post #1 of 7 Old 11-16-2008, 03:39 PM Thread Starter
edgeflyer's Avatar
Frame guys Help!!!!
O.K. so I lowsided at 70ish, bike slid for a year or so, then performed gymnastics as it went off the track. so I get the bike put back together and on my test ride I notice the bars are slightly right. CRAP! so I pull the front apart and as I do I figure the only thing that could cause this is bent forks or bent lower clamp. I put a dial on the forks and they're true. so I check the lower clamp and I think its bent ever so slightly. but after staring at the front for 2 weeks I don't know what I see anymore. the top of the right fork leg sits 3/8"
further back than the left. the wheel also points left. so am I right in assuming that with the forks straight the only thing that could cause this is the lower clamp? I'm positive the frams straight for arguments sake. so if thats the case is there any posibility of being able to straighten that small of a tweak out or would you wind up going too far. if you could would you cold bend it? I got one off ebay and it was off a totaled bike for shure so I figure any I get will be worse than mine, and a new one is 300 plus. I am obsessive about stuff like this and its driving me crazy. would you worry about it for a race bike? surely it would at least cause some stiction with the fork? any thoughts?
edgeflyer is offline
post #2 of 7 Old 11-16-2008, 04:22 PM
Bigprfed22's Avatar
Images: 93
forks are tough to bend with out impact, loosen the triple the re tighten, clip ons etc... then when reassembled you should be able to let go and the bike shouldnt drift to one side.
btw your race bike should be inspected thoroughly as it sees more stress than a normal road bike would.
"Bs stops when the green flag drops"
Bigprfed22 is offline
post #3 of 7 Old 11-17-2008, 07:26 AM Thread Starter
edgeflyer's Avatar
yeah I actually had the whole thing stripped down including taking the lower clamp off, put it on a bench and thats when it looked like one side had more of a gap than the other. its been 2 weeks since I had it tore down so I can't remember what it looked like anymore. there is a lot of optical illusions after stairing at the fork setup for a while. but after I put it back together its still the exact way.I just wanted to get some insight before I pull it down again to remeasure. Thanks
post #4 of 7 Old 11-17-2008, 07:33 AM
MIA Ex-Mod
Tread70's Avatar
Swap it out it would be extremely hard to get the triple back near 100%. It could also be the upper causing it. Take off the upper and loosen everything and snug it back and see if it is still tweaked, if so then its the lower if not then upper.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #5 of 7 Old 11-18-2008, 06:43 PM
Contact www.gpframeandwheel.com Gerry can fix nearly anything. I have used his services many times in the past and always had excellent results.
amunoz is offline
post #6 of 7 Old 11-18-2008, 07:36 PM Thread Starter
edgeflyer's Avatar
perfect.
post #7 of 7 Old 11-18-2008, 08:59 PM
roadracer98's Avatar
Has anyone ever been riding in a straight line at a moderate pace and looked down at thier top tripple clamp ? Check it out sometime. I had several bikes NEW that I had that were never crashed that had the top tripple clamp cranked to the right .
2010 BMW S1000RR- 2008 CBR1000RR
roadracer98 is offline
From all the guys down south to all you guys up north. 10 speed The Out House 11 12-08-2007 04:34 PM
what are you 06-07 guys using for frame sliders? 10 speed Performance and Tech 14 02-13-2007 10:39 PM
what do you guys think of these? duckguy The ZX-10R 13 02-05-2006 04:54 PM
Need your help guys... trackaddict The ZX-10R 10 01-31-2005 06:37 PM
well guys think i met someone that could last scottymizt The Out House 33 01-27-2005 10:11 PM
