Found Buzzing noise!!! loose Ign Key!!! - Kawasaki ZX-10R.net
post #1 of 11 Old 06-05-2007, 07:04 PM Thread Starter
slipngrip's Avatar
Exclamation Found Buzzing noise!!! loose Ign Key!!!
put some O-rings on your key, after you cut that sh#t off the top of it,
slipngrip is offline
post #2 of 11 Old 06-05-2007, 07:41 PM
god thank you. that shit is driving my up the fucking wall.
hobbes4star is offline
post #3 of 11 Old 06-09-2008, 08:54 PM
grn08's Avatar
ok maybe i took the short bus to school on Tuesday's but could you explain alittle more on what needs to be done to stop this this noise
grn08 is offline
post #4 of 11 Old 06-09-2008, 09:40 PM
fbmbks's Avatar
Send a message via AIM to fbmbks
thank god someone said it, i wasnt catching the drift either
fbmbks is offline
post #5 of 11 Old 06-09-2008, 10:03 PM
Still here
ZX10Miami's Avatar
Stack small o-rings onto your key so that it applies a little pressure when it is in the ignition and it cures the buzz on some 2nd gens.
That fix and one for a different buzz on 1st gens have been posted a lot and should be stickied.
You can also use a small pice of black vaccum line or other tubing and cut it to fit.
Sarah Palin and friends can call it a snow machine all they want but Yamaha, Polaris and Bombardier plus the related magazines all seem to call them Snowmobiles.
Snow machines create snow on ski slopes. Just sayin'
ZX10Miami is offline
post #6 of 11 Old 06-09-2008, 10:11 PM
CB160's Avatar
Sounds like your mufflers are too restrictive? Lol!
I have A&R's installed, never heard any buzzing....
'06, Smoked windscreen, Galfer S/S brake lines, GiPro TRE, Speedohealer, Custom lighted fender eliminater, A&R Baffles, "Real" Ohlins Damper, added a seat cowl, so now I'm a true 'poser'..... Power mods - Why? Too much for me already!
CB160 is offline
post #7 of 11 Old 06-09-2008, 10:19 PM
Still here
ZX10Miami's Avatar
Some do it some don't- there was a problem with the antitheft bolts that hold the ignition to the tree on some 2nd gens. They weren't getting tightened enough before the antitheft part snapped off (for lack of better wording.)
That fix made some people's buzzing go away but others found the problem to be in the ignition switch itself and the o ring or rubber tube fix helps that.
Then on the 1st gens there was the space under the front fairing where they were rubbing and the fixes for that with felt or whatever.
post #8 of 11 Old 08-10-2008, 12:50 PM
took my 06 zx10r to the shop yesterday for that buzzing sound coming out of the ign. they drilled out the bolts and put some regular bolts on. that solved the problem. one way i noticed the ign was the problem was that it had some play in it. i checked out previous years and no movement at all. thanx for the info
rnaranjo is offline
post #9 of 11 Old 08-10-2008, 12:56 PM
Judge Dredd Mod
mr_honez's Avatar
Never heard anything on mine yet but probably will now that I know.
BURNOUT.....
mr_honez is offline
post #10 of 11 Old 08-10-2008, 03:48 PM
tigersurvival's Avatar
Send a message via AIM to tigersurvival Send a message via MSN to tigersurvival Send a message via Yahoo to tigersurvival
My 08 will buzz sometimes too, I think it comes from the ignition area as well. Hmmm.. time to experiment.
tigersurvival is offline
Warranty covered buzzing on 06 - 10r vegas10r Performance and Tech 29 12-26-2006 07:28 PM
ZX10R "Buzzing Noise" at 4000rpm Mojo Performance and Tech 10 08-31-2006 10:07 PM
Solved The 06 Ignition Buzzing LOU_DIAMONDS36 The ZX-10R 2 08-28-2006 07:35 AM
Buzzing Sound Stopped - Now a new soundwhat is this sound zx10x2 The ZX-10R 2 06-21-2006 12:12 AM
where is all the buzzing coming from on my ZX10? busaforhire The ZX-10R 42 02-02-2006 10:49 PM
