Fork tubes removal...... - Kawasaki ZX-10R.net
post #1 of 12 Old 08-22-2008, 02:23 AM Thread Starter
The Movie Goer!
ZiG 9th's Avatar
Send a message via AIM to ZiG 9th
For those of you who have removed your own fork tubes, what all needs to come off to remove the forx? Does the front nose fairing need to be removed?
ZiG 9th is offline
post #2 of 12 Old 08-22-2008, 03:52 AM
Big Daddy's Avatar
Images: 38
lets try the proper section shall we.
Big Daddy is offline
post #3 of 12 Old 08-22-2008, 07:03 AM
FuTAnT's Avatar
Images: 7
It's been a little while, but no need to remove the front fairings. Put the front end up on a head lifter stand, or suspend it via the headstock.
Take the front calipers, tyre and mudguard off. Loosen the clip ons and upper and lower pinch bolts on the triple clamps. Forks will just slide out. Pretty simple really. Make sure when you put them back together that you get the cabling right (the throttle cables).
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
'85 GSX250S -> '96 ZX6R -> '98 ZX6R -> '00 ZX6R -> '03 CBR954RR -> '04 ZX10R -> '02 ZZR250 -> '06 ZX10R -> '08 KTM 990 ADV
Last edited by FuTAnT; 08-22-2008 at 09:47 PM. Reason: said the same thing twice when I meant clip ons.
FuTAnT is offline
post #4 of 12 Old 08-22-2008, 08:44 AM
Dont forget to loosen the clip ons as well.
NYC_ZX10 is offline
post #5 of 12 Old 08-22-2008, 11:27 PM Thread Starter
The Movie Goer!
ZiG 9th's Avatar
Ok thanx fellas! Appreciate it!
ZiG 9th is offline
post #6 of 12 Old 08-22-2008, 11:56 PM
FuTAnT's Avatar
Images: 7
Indeed, I typed the wrong thing, but was thinking of clip ons. Doh!
FuTAnT is offline
post #7 of 12 Old 09-03-2008, 06:58 PM Thread Starter
The Movie Goer!
ZiG 9th's Avatar
How do I loosen the bolts on the lower triple tree? Itz hardly any room with the front nose fairing on to get a wrench in there an loosen them up.
ZiG 9th is offline
post #8 of 12 Old 09-03-2008, 07:38 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
I was actually able to get a combination wrench in there and get mine, there is just barely enough room, but be carefull one slip and the bolts are rounded.
9R to 10R is offline
post #9 of 12 Old 09-03-2008, 08:13 PM
FuTAnT's Avatar
Images: 7
You can still turn the bars while the front end is up to get clearance. Use a socket or a ring spanner, should be able to get in there no drama.
FuTAnT is offline
post #10 of 12 Old 09-03-2008, 09:33 PM Thread Starter
The Movie Goer!
ZiG 9th's Avatar
I got 'er dunnnnnn!!!! Thanx radical dudes!
ZiG 9th is offline
Sliding Fork Tubes on 06? SAkI The ZX-10R 12 04-05-2008 08:59 AM
Painting Fork Tubes. 06blackpearl General Motorcycle Discussions 9 03-24-2008 07:40 PM
Does anyone know the dia. of the Fork tubes on a 2005 BornSinner Performance and Tech 2 01-15-2008 04:38 PM
Removing Fork Tubes...Tricks ? Felix el gato Performance and Tech 2 12-05-2007 09:00 PM
Question: What size is the 05 ZX10R Fork Tubes? Corvette95 The ZX-10R 9 10-12-2005 09:53 PM
