Fork stiction/friction - Kawasaki ZX-10R.net
post #1 of 29 Old 01-03-2005, 11:19 AM Thread Starter
MIA Post Whore
miykl's Avatar
Question Fork stiction/friction
Originally Posted by champ91
The pich your referring to exists in the axel and the axel nut itself. Adding sliders to the outside of the axel and axel nut will not increase or decrease the pinch. They clamp to the outside of the axel/nut. No matter how much you tighten the sliders you will not make the axel and nut to tighten causing the forks to pinch in.
This was grabbed from the fork slider thread. I must be out the loop on the problem and the solution. Anyone care to fill me in?
miykl is offline
post #2 of 29 Old 01-03-2005, 11:30 AM
Big Daddy's Avatar
Images: 38
What champ91 is referring to are sliders (just like frame sliders)that mount to the outside of each fork leg helping to prevent damage in a crash.
As for stiction it is sometimes possible (depending on the fit) to pinch the bottom end of the tubes together when tightening the axle/axlenut therefore creating more stiction than needed/wanted at the bottom of the stroke. Top Shelf has found this to be true and has commented on it in another thread.
Big Daddy is offline
post #3 of 29 Old 01-03-2005, 12:13 PM
Do a search for RedRider on the kawiforums and I think he was the thread poster on this. He got a GSXR axle and machined it. The design of the 10r and 636 axle is different. The 636 left side bolt has a lip that pulled in on the forks, while the 10r has the bolt that slides into the fork.
BNninja is offline
post #4 of 29 Old 01-03-2005, 12:34 PM Thread Starter
MIA Post Whore
miykl's Avatar
This is all my search yielded:
Originally Posted by Top Shelf
P.S. BD-I have some interesting info to share with you about setup that I have been discovering of late. The suspension guy I have been working with recently has been experimenting with some different things. We also found a MAJOR source of stiction in the front end. PM me and I'll share.
miykl is offline
post #5 of 29 Old 01-03-2005, 01:01 PM
you are searching the wrong forum...i will find it and be back.
BNninja is offline
post #6 of 29 Old 01-03-2005, 01:04 PM
http://kawiforums.com/forum/topic.asp?TOPIC_ID=18173
Here it is with pics in the thread
BNninja is offline
post #7 of 29 Old 01-03-2005, 02:50 PM
OK here's the info on my efforts to reduce the stiction. What we found was that even following the service manual to a T, the forks were being pulled together by the lips on both sides of the axle. The GSXR axle as mentioned does not have a lip on both sides and allows one side of the axle to slide in to the fork leg and pinch the wheel. In order to solve the issue, we machined the lip off the receiver end of the axle (that requires the allen tool) and found that we could pinch the wheel better as well as virtually eliminate stiction. The only trick is making sure that the wheel is centered in the forks, but it will definitely work to eliminate the stiction.
Top Shelf is offline
post #8 of 29 Old 01-03-2005, 02:59 PM Thread Starter
MIA Post Whore
miykl's Avatar
Considering my usage (sport touring/straight line racing/occasional trip to decent curves), will I bennifit from doing this mod? Or is the stiction only evident when pushing hard on the track?
miykl is offline
post #9 of 29 Old 01-03-2005, 03:06 PM
It will dramatically how well your suspension works no matter where you ride. We found about 30mm difference in stiction at its worst which equates to about a 3rd of the travel in the fork. Not good. Any time you load up the front tire, the suspension cannot work as well as it should. For a test, try unloading the front end and measure how long the sliders are. Then let the front end come to rest on its own GENTLY!! Do not let it bounce down. Measure the length of the sliders. Then press the front end down, compressing the forks, and let them rise under there own power. Measure again. The difference between the two is exclusively stiction. Obviously there will be some stiction just because of the design of any fork. But ideally it should be minimal. As an example, Ohlins Superbike Forks have between 2-5mm of stiction, while a good set of stock forks has 10-15mm. Mine like I said before had between 20-30 depending on how the front wheel was put in and how much torque was put on the axle.
post #10 of 29 Old 01-03-2005, 03:06 PM
Big Daddy's Avatar
Images: 38
Miykl my gut feeling is its a 'win win' deal no matter how, what or where ya ride.
but then i'm old.
Sato fork sliders SuicideMachine Pictures and Videos 63 01-08-2005 10:49 AM
Bike Towing to Philly! / Securing using straps RichTJ99 The ZX-10R 27 07-04-2004 12:54 PM
