fork seal replacement - Kawasaki ZX-10R.net
post #1 of 8 Old 06-10-2007, 03:53 PM Thread Starter
logmaster's Avatar
After searching the threads, can someone tell me that yes, definately, I need the fork compression tool before I change them?
Thanks.
logmaster is offline
post #2 of 8 Old 06-10-2007, 04:07 PM
chrisbsvc's Avatar
NO you do not need it to replace seals and fluid. Basically just unscrew the top cap then hit the bottom allen bolt with an impact. The spring and damper will just slip right out leaving you with only the fork inner and outer tubes.
04-05 i'm 100% sure
06-07 think so
chrisbsvc is offline
post #3 of 8 Old 06-10-2007, 04:23 PM
04-05 i'm 100% sure
06-07 think so
Is there a better seal to go with or just replace with the oem seals? I have an 06 and my right seal is leaking.
jessiah1 is offline
post #4 of 8 Old 06-10-2007, 05:17 PM Thread Starter
logmaster's Avatar
Mine's an '04
Great! Thanks!!
post #5 of 8 Old 06-10-2007, 06:27 PM
Dragone's Avatar
Images: 11
Normally, oem seals have worked on a change out without any issues. Make sure and clean any burrs on the leg. Have fun.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #6 of 8 Old 06-10-2007, 10:33 PM
chrisbsvc's Avatar
OEM hands down. I have had little to no luck with the "leak proof" seals. By the way cut a grocery bag in half and lube it with oil, then slip it over the inner tube so that the new oil seal can slide down over it without being cut by the holes that are in the tube itself. If not you may end up doing the job again.
If you have any other questions feel free to PM me or e-mail.
post #7 of 8 Old 06-11-2007, 09:25 AM
Killerzxrider's Avatar
Talking The new Guy!
Hello to all, I have been around for a few months just reading different threads and you guys do I great job communicating info.
Killerzxrider is offline
post #8 of 8 Old 06-11-2007, 02:12 PM
Thanks for the info, I may contact you when I decide to get my hands dirty. Im hopeing my small leak that is just coating the fork sleeve will stay that way till winter when I wont lose ride time!
jessiah1 is offline
Fork Seal Part # help smikels The ZX-10R 7 05-17-2011 12:22 AM
Fork Seal nmorris02 The ZX-10R 3 05-22-2007 05:54 PM
Fork seal oil ? wingnut Performance and Tech 14 11-09-2006 11:31 AM
Fork Seal Problem GPD270 Performance and Tech 11 02-28-2006 06:30 AM
Fork seal update... Ground Zero Performance and Tech 4 07-28-2005 01:23 PM
