foam for the gas tank? - Kawasaki ZX-10R.net
post #1 of 7 Old 08-01-2007, 07:18 PM Thread Starter
WOODYZX10R's Avatar
http://evomx.com/first.html
i have heard that foam like this will keep gas from sloshing during braking and turning. what do you think? looks real easy just squish it up and push through the gas filler hole. life of 20+ years in the tank.
who will be the guinea pig?
2004 ZX10R, mostly kinda stock
WOODYZX10R is offline
post #2 of 7 Old 08-01-2007, 07:31 PM
jstwkd1's Avatar
I think our bikes get bad enough gas mileage. Sounds good for the track though.
jstwkd1 is offline
post #3 of 7 Old 08-01-2007, 07:33 PM
inappropriate
hesaves0211's Avatar
Images: 67
"most often felt in tight turns, breaking bumps and G-outs where your 12-15 lbs of fuel can feel more like 25-30 lbs of fuel sloshing from front to back and side to side. EVOmx foam stabilizes the fuel in your gas tank, therefore allowing you to maneuver your vehicle as if it were 15-20 lbs lighter. Best of all is the fact that EVOmx foam is so porous that is only takes up 2-3% of the volume of the tank thus allowing you to maintain essentially the same volume of gas. "
im not to sure about volunteering. but i doubt a foam removes the effects of gravity. of coarse the foam will make it appear as if the fuel isnt moving around because when a liquid moves against a metal the metal will not absorb the impact as well as the foam would. hence the foam merely silences the liquid. i think the reduced weight feeling would all be in your head. but give it a shot!
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #4 of 7 Old 08-01-2007, 07:33 PM
Ruthless Racing's Avatar
Images: 9
Schnitz sells the same thing.
http://secure.mycart.net/catalogs/ca...showprevnext=1
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #5 of 7 Old 08-01-2007, 07:37 PM
Green Hippie
treyzx10r's Avatar
just adds more weight IMO
VAE VICTUS!
treyzx10r is offline
post #6 of 7 Old 08-02-2007, 06:56 AM
Mustard's Avatar
the foam would stop the sloshing, due to its density it would take longer for the fuel to move from one position to another as it has to find its way through all the little holes, whereas without the foam it could just fall to the otherside of the tank without any obstruction.
Once i thought more than two strokes was masturbation. Now I realise that 4 feel better, and who am I to argue with my feelings.
05 Black/white road/track zx-10r. Race fairings with stock headlight custom blinkers, Brembo MC, HEL braided lines, Toby dampner, Mustard Block-off plates, plugged airbox, Mustard Heel guards, Mustard Ram-air tube support, custom flip-up rear fender eliminator, custom rear fender, custom seat cowl, corsa 111's.
Mustard is offline
post #7 of 7 Old 08-02-2007, 09:22 AM
I believe this stuff is designed for endurance racing where they have 7 gallon gas tanks...that's a lot of weight in fuel
Lawdog78 is offline
Clean the engine with Sea Foam? hotstang46 The ZX-10R 12 05-14-2007 12:17 AM
who know Tank foam FPZ The ZX-10R 6 03-26-2007 10:38 PM
Tank Bra hollywood99 The ZX-10R 11 09-22-2006 11:22 AM
Tank Pad? mjg68901 The ZX-10R 10 09-15-2006 08:29 PM
Cut down tank for ZX-10? rotts4u Wanted: Buy or Trade 2 05-13-2005 01:02 AM
