Fix for FI light when removing secondary actuator and tps? - Kawasaki ZX-10R.net
post #1 of 12 Old 10-24-2010, 01:52 PM Thread Starter
strkd50's Avatar
I'm in the process of removing the secondary rod from my TBs. Some one has to of found a way to trick the ecu that the actuator and tps are still there. So what is it? I would appreciate any and all help.
strkd50 is offline
post #2 of 12 Old 10-24-2010, 01:56 PM
09zx10miami's Avatar
Contact garth285 I believe he has a fix for this..
09zx10miami is offline
post #3 of 12 Old 10-24-2010, 01:58 PM Thread Starter
strkd50's Avatar
I have before without a response......I will try again tho. Anyone else got one? For my '08 by the way.
strkd50 is offline
post #4 of 12 Old 10-24-2010, 02:49 PM
NinjeR's Avatar
Just curious to what the real benefit of removing the rod? If the response is weight savings, how much could that rod possibly weigh? 2 ounces perhaps? Just wondering since a few people here has been trying to eliminate the rod, so no disrespect with the question.
NinjeR is offline
post #5 of 12 Old 10-24-2010, 03:03 PM
its not for the weight, its for the air flow obstruction that the rod creates. the 2' tps would need something similar to "servo eliminator" to trick it
mityaz is offline
post #6 of 12 Old 10-24-2010, 03:06 PM Thread Starter
strkd50's Avatar
The rod its self doesn't weigh much of anything but the actuator has a bit to it. However my main reason for removing the rod is to make the intake track as free flowing as possible. I figure while I have everything completely apart for winter build I would like to make all the "little bits" as efficient as I can get it.
strkd50 is offline
post #7 of 12 Old 10-24-2010, 05:54 PM
NinjeR's Avatar
Now is the actuator in the middle? I''ll assume so, so could you just cut the rods at the points I outlined so you get the free effect and still have the uncut rod still hooked up so that it would not throw off the FI light?
Or does it work differently?
NinjeR is offline
post #8 of 12 Old 10-24-2010, 06:03 PM Thread Starter
strkd50's Avatar
You cant because the rod is what connects the actuator to the tps on the side of the TBs.
strkd50 is offline
post #9 of 12 Old 10-24-2010, 08:20 PM
NinjeR's Avatar
gotcha, I thought I might have been on to something for a sec lol
NinjeR is offline
post #10 of 12 Old 10-24-2010, 08:41 PM Thread Starter
strkd50's Avatar
Yeah I wish it were only that easy
strkd50 is offline
removing secondary butterflies M109R Performance and Tech 3 03-17-2010 09:43 PM
Need to buy a Actuator for secondary throttle plates angstroma2004 The ZX-10R 8 11-29-2009 10:06 PM
Removing the Secondary Butterflies Zuperman Performance and Tech 15 04-01-2009 11:00 AM
removing secondary flies fbmbks Performance and Tech 1 09-11-2007 07:23 AM
secondary butterflies and actuator hongthaomurphy Performance and Tech 13 07-16-2006 08:09 AM
