First Gen. Ignition Problems... - Kawasaki ZX-10R.net
post #1 of 27 Old 11-18-2008, 08:36 AM Thread Starter
cecil_kawi's Avatar
Send a message via AIM to cecil_kawi
My 2005 10-R won't start. Actually, it won't do anything. No lights on the gauge, no fuel pump priming, no nothin'!! At first it was very spuratic, but now it won't do anything. This past weekend I did get it to start, went for a ride, and then went to move it again and it won't do anything! Yesterday when I turned the key on the fuel pump primed, lights came on, and then as soon as I pushed the button to start it, everything cut out. The kill switch does not seem to have anything to do with the problem, which leads me to beilieve it is a bad ignition. Has anybody else had problems with first generation ignitions? If so, do I need to get a whole new ignition, or is there a way to fix it? Any help on this issue would be very much appreciated.
You don't know what you can do until you know what you can't do...
cecil_kawi is offline
post #2 of 27 Old 11-18-2008, 08:38 AM
MIA Ex-Mod
Tread70's Avatar
I would check the battery connections and make sure the battery is good. Sounds like a bad connection though or a faulty ground.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #3 of 27 Old 11-18-2008, 08:42 AM Thread Starter
cecil_kawi's Avatar
Tread
Battery connections are good... I'm going to remove the ignition tomorrow, check all the wiring, and re-install it. Hopefully if it's a ground problem that will help.
post #4 of 27 Old 11-18-2008, 08:44 AM
Still here
ZX10Miami's Avatar
Load test the battery?
It could show voltage at rest but still be screwed.
Just a thought.
Sarah Palin and friends can call it a snow machine all they want but Yamaha, Polaris and Bombardier plus the related magazines all seem to call them Snowmobiles.
Snow machines create snow on ski slopes. Just sayin'
ZX10Miami is offline
post #5 of 27 Old 11-18-2008, 09:07 AM Thread Starter
cecil_kawi's Avatar
The only thing that debunks that is the fact that one minute it starts like a champ, and the next it's got nothin! Thanks though
post #6 of 27 Old 11-18-2008, 09:13 AM
FAF
Rent this space
Its a continuity problem, maybe a dirty connection and nothing major, likely causes are the frame to engine ground and the positive to the main fuse and the starter relay from the battery.
FAF is offline
post #7 of 27 Old 11-18-2008, 09:20 AM
10roller's Avatar
pull up your seat and check the fuses. you probly got a blown fuse, happened to me randomly couple years ago.
10roller is offline
post #8 of 27 Old 11-18-2008, 10:17 AM
Still here
ZX10Miami's Avatar
Sometimes batteries act weird right before they give up.
Is it the original battery?
Just hoping it was something simple.
post #9 of 27 Old 11-18-2008, 10:52 AM
Supercharged Mod
I betcha the battery has an internal problem.
Hook up booster cables from the battery cables to a known-good 12-volt battery (example, the one in your car) - do this with the ignition switched off, please! - and see if it starts and runs reliably in that state. Do this with the ground connection to the battery disconnected (so it is connected ONLY to the known-good battery) to remove the possibility that your battery has an internal sporadic short-circuit. If it works properly when connected to some other battery, now you know what the issue is.
GoFaster is offline
post #10 of 27 Old 11-18-2008, 02:10 PM
EliteConcepts's Avatar
ignition
i had a very similar problem on my old 6r, it was a bad connection inside the ignition switch . re soldered the connection and it never happened again. looked like a bad solder joint. let us know what ya find
05 magma red ZX10R w/ Erion slip-on
EliteConcepts is offline
Ignition Map for 06-07 zx-10 redline659 Performance and Tech 0 07-28-2008 10:52 AM
problems with ignition Funaru Performance and Tech 11 10-03-2006 05:53 PM
06 ignition tbcustomz Wanted: Buy or Trade 0 09-24-2006 10:59 AM
"Ignition on" diagnostic and starting problems Zesty10R Performance and Tech 3 06-22-2006 08:36 PM
06 Ignition problems mrsuprafreak The ZX-10R 13 05-10-2006 09:24 PM
