Finally the GARTHMOTOR is getting closer to being done... high velocity head porting. - Kawasaki ZX-10R.net
post #1 of 220 Old 12-05-2008, 06:01 PM Thread Starter
Speed Freak
garth285's Avatar
We'll I haven't posted about my bike in quite a while... I've had her apart for probably 3 months now.... just haven't had the time to put her together and I've been weighing the options I have... I was going to put my KWS head back on and do a valve job on it and do a before and after with a different ported head....
Anyways....my head using a different head porting idea.... its a high velocity port that actually speeds up the air speed on its way into the cylinder. This has been proven on the street, track, strip and everywhere else as being much more efficient.... there's a science to actually making the air speed pick up but we have amazing results with the porting...
I have my complete bottom end assembled as of right now and just waiting for the head to receive a competition valve job, port match intake boots and re-surface the head. Going to go .002-.004" to pick up a bit more compression as well.... Going to run my Kawi intake race cam and a stock exhaust or a stock intake on the exhaust side. had piston skirts coated, new rings, wristpins and circlips, polished connecting rods to mirror finish and replaced all low end bearings... As for HP I'm not sure yet, I dont know what the bike will dyno on this dyno but I do know that with 380lbs FULLY WET and lets say 180-195hp .... she should definitely hauls some serious butt.... I got a few guys back home that want a piece of the 10 so we'll see.... One other thing, I'm using a 06 cyl head for a smaller intake valve for added velocity... bigger isn't always better...
These ports are quite a bit smaller then stock but the power you will gain from smaller intake ports is amazing... we got a BONE STOCK ZX-14 but with degreed STOCK cams make 188hp on motor when they normally make about 178-180....
Well heres some pics of the head..... first pic is stock port second is epoxy'ed high velocity porting....
exhaust clean up....
BTW.... normally a high velocity head port job like this including valve job runs normally $1,000 valve and springs are extra of course....
garth285 is offline
post #2 of 220 Old 12-05-2008, 06:08 PM
jcw
They say you can do that on the exhaust side as well, raise the floor to improve flow. Especially on transverse 4 cylinders that have to make an immediate turn on the exhuast exit. I haven't seen it much on intakes as the flow usually is straight down from the airbox.
Check out the divider, I've heard widening properly like an airfoil also improves head flow and reduces turbulence.
Very nice.
jcw is offline
post #3 of 220 Old 12-05-2008, 06:11 PM
Superbike1's Avatar
Images: 16
Can't wait to see the results!
Is it Fast?
Superbike1 is offline
post #4 of 220 Old 12-05-2008, 06:11 PM Thread Starter
Speed Freak
garth285's Avatar
yeah, they do it on a lot of bikes that have just regular ports, if you look at the 10r the exhaust ports are raised to help that turn out into the headers.... its very hard to do it on the exhaust side since you usually have to have someone who can TIG weld very good and you have to do it piece by piece since you don't want to heat up the head and warp it....
garth285 is offline
post #5 of 220 Old 12-05-2008, 06:14 PM
Superbike1's Avatar
Images: 16
Smile
oh yea! I knew I had seen this somewhere before,years ago. www.mototuneusa.com
Is it Fast?
post #6 of 220 Old 12-05-2008, 06:20 PM Thread Starter
Speed Freak
garth285's Avatar
yeah, I read about some of his stuff....
Actually there was a guy down south who used to port heads like this for over 20 years and built some of the fastest head around but he got burnt out and quit.... he did the same exact thing and I've wanted a high velocity head for a long time.... just so happens the place im working at my boss has been doing this for 8 years so far.
some people think epoxy will break away and explode a motor but he has a customer with a Harley with a epoxyed head and its been running for over 2 years and if a harley cant shake it loose nothing will.... actually one time a bike blew on the dyno and the intake valve shot back up inside the head well they had to cut the epoxy to get the valve out, thats how tough that is....
garth285 is offline
post #7 of 220 Old 12-05-2008, 06:22 PM
ZX-10R_Sinner's Avatar
Nice, very nice Garth. Can't wait to see the results. With any luck I think it's possible that I'll send the head off my 07 down to you in about a year, that way I can gain some power and get the valve service done in one shot! Thanks for coming back and posting, can't wait to see ya whooop up on some other bikes down there.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #8 of 220 Old 12-05-2008, 07:05 PM
axo250's Avatar
Send a message via AIM to axo250
Hey Shawn, can't wait to see the results man! Definitely a different philosophy. I'm interested to see how it works. Did you dyno your bike before on the dyno up there?
"Besides, my ZX-10R eats GSX-Rs for breakfast." -- SportRider Magazine Article
axo250 is offline
post #9 of 220 Old 12-05-2008, 07:08 PM
I have a set of race cams in perfect condition, cheap cheap cheap, if your interested, and I'm right down the street from you in sunny Palm Beach Florida.
Shameless is offline
post #10 of 220 Old 12-05-2008, 07:46 PM
zx10Duran's Avatar
can I send you mine?
zx10Duran is offline
porting+thinner head gasket mr wael Performance and Tech 73 11-02-2007 01:26 PM
Head porting Nevaeh Speed The ZX-10R 9 10-17-2007 10:20 PM
Cylinder Head Porting pec2903 Performance and Tech 2 07-19-2007 10:30 AM
head porting? speedfreak Performance and Tech 2 03-21-2005 06:24 AM
Closer and closer to becoming a police state...... RUNNINHORN The Out House 12 06-13-2004 04:31 PM
