Failed at cat removal - Kawasaki ZX-10R.net
post #1 of 3 Old 03-30-2008, 04:22 AM Thread Starter
Guys
After abit of advice...
Tried to take mid / y pipe yesterday in order to knock the cat out of it.. several of the allen bolts that connect to header pipes are rusted out so key just spins. Any ideas on how to easily remove mid pipe still ?
I cant believe kwak didn't use stainless in such a place... or maybe the bolts are stainless but just to soft to turn.
Fluke is offline
post #2 of 3 Old 03-31-2008, 05:37 PM
chriswillis's Avatar
happened to me too mate :(
I heated up the bolts until they were glowing red hot and undid them with pliers - a bastid of a job but worth it in the end. Used stainless ones when i put it back together.
Get flames and poppin' noises - very tidy!
chriswillis is offline
post #3 of 3 Old 03-31-2008, 06:24 PM
dunkchamp55's Avatar
Send a message via AIM to dunkchamp55
im glad i got to mine with just 1300 miles on her. no troubles what so ever....did you try soaking them with some sort of rust remover? make sure you have the right size allen wrench
dunkchamp55 is offline
ECU Failed on 04 10r? twonk Performance and Tech 9 07-04-2007 02:35 PM
CHAIN Failed-Cracked Mystery case? ANY CLUES? ILOAD2 Performance and Tech 20 08-07-2006 03:14 PM
Bar end removal Stalker Performance and Tech 7 08-02-2006 09:38 AM
Air box removal? fun2fly Performance and Tech 37 12-19-2005 12:35 PM
