Gen 1: 2004-2005 FactoryPro Shift Star Kit - Kawasaki ZX-10R.net
post #1 of 8 Old 06-13-2012, 09:59 PM Thread Starter
I need to open my clutch and for a long time I was thinking to bought the FactoryPro Shift Star Kit.
Does anyone have this installed? It's made the shift change really better?
They say that need to remove the oil pan and exhaust system too to install, it is really necessary?
Here the link about...
http://www.factorypro.com/Prod_Pages/prodk95.html
Scroll to bottom for the kit...
spirity is offline
post #2 of 8 Old 06-13-2012, 10:15 PM
clutch master's Avatar
Yes it is necessary to remove oil pan to get to the retaining clip that holds the shift shaft in, also I would recommend replacing that clip, sometimes you have a tendency to stretch it open to far and it looses some of it's holding power which would alow shift shaft to be pushed out of position when re installing shift linkage (ask me why I'm suggesting this). As far as if it's better would know, I run an air shifter and drag race only. I would do the mod though every little bit helps.
clutch master is offline
post #3 of 8 Old 06-13-2012, 10:32 PM Thread Starter
Great, good to know!
Just to see if is clear, you mean the item 480 (480J1400) in the link bellow?
http://www.partshark.com/fiche_secti...005&fveh=21182
spirity is offline
post #4 of 8 Old 06-15-2012, 12:19 AM
Yes thats it. Its basically a snap ring retainer.
post #5 of 8 Old 06-15-2012, 10:10 AM
badassjake's Avatar
or...........got and get the OEM 2005 shift star, spring and arm for like a 1/3 the cost!!
badassjake is offline
post #6 of 8 Old 07-03-2012, 05:54 PM
badassjake's Avatar
like this !!................. $60.00
post #7 of 8 Old 09-10-2013, 11:18 PM
lenshead's Avatar
Sorry to resurrect this old thread, but I see the cam (shift star), positioning arm and spring have different part numbers from '04 to '05
besides the above mentioned retaining clip, and an oil pan gasket, is there anything else I should order in advance before attempting this job?
Thanks
lenshead is offline
post #8 of 8 Old 09-11-2013, 01:00 AM
badassjake's Avatar
nope. mod and enjoy
Gen 1: back cutting gears and FactoryPro Evo shift kit 1madkaw Performance and Tech 7 01-08-2012 11:28 PM
08-09 Evo Shift Star strkd50 Performance and Tech 2 04-18-2010 09:47 PM
EVO Shift STAR Kit BackMarker Vendor Deals 10 11-04-2009 03:10 PM
shift star splatmaster Performance and Tech 5 07-13-2006 07:52 AM
Shift Star porschedr Welcome Newbies! 0 06-21-2006 03:09 PM
