Factory Pro Velocity Stacks install? - Kawasaki ZX-10R.net
post #1 of 13 Old 12-21-2009, 01:21 PM Thread Starter
05pearlmagma10r's Avatar
I'm attempting to install the stacks and for the life of me I can't get the stacks into the aftermarket boots once the boot is in the stock boot clamp. Factory Pro's instructions are vague and if anyone has any tips I'd appreciate it greatly. Thanks.
05pearlmagma10r is offline
post #2 of 13 Old 12-21-2009, 01:25 PM
Quick10's Avatar
use some soap it will help to lubricate the boots
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #3 of 13 Old 12-21-2009, 02:14 PM
dirt ninja's Avatar
Images: 9
Are you sure you got stacks for the first gen and not the second gen? Stacks are slightly different in size between the two.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #4 of 13 Old 12-21-2009, 08:12 PM Thread Starter
Valid point. The website doesn't have model specific part numbers. The engraved number on the tall stacks is V45.3-60 if anyone can varify the model. If not hopefully their open this week.
Just did a google search and got a list of German websites relating that part number to a GSX-R 1000 so I might have a slight problem.
post #5 of 13 Old 12-21-2009, 08:21 PM
Gone
mine were really stiff too mate...
i put the rubber boots in the 'figure of eight' oe clamps first then used lots and lots of wd-40 to press them in...
as in put base on the floor and press down on the stacks with your palms as you wiggle them in. once half in get a srcrewdriver aswell to help ease the rubber boots up & around the stacks' bases. time and patience thats all. i thought something was up too when i first tried to install them.
tony83 is offline
post #6 of 13 Old 12-21-2009, 08:46 PM Thread Starter
Thanks I was losing my mind. Last time I checked I wasn't this inept.
post #7 of 13 Old 12-23-2009, 03:43 PM
you can also try warming the rubber up before putting soap on it. depending on the rubber somtimes it makes it a little more plyable
general01 is offline
post #8 of 13 Old 12-23-2009, 04:08 PM
Justin's Avatar
Did you have any luck? If not when I get home I can check my stacks since the bike is taken down for winter maintence.
2004 ZX-10R - Powder coated Kawasaki green wheels, attack performance bars, PC III, Ivans GRE, vortex front sprocket, vortex cat 5 black rear sprocket, vortex rear sets, RK 525 green chain, galfer ss brake lines, custom frame sliders & and swing arm spools, BMC air filter, Scorpion street extreme exhaust, DB screen, Green integrated tail light kit, OEM seat cowl, speedohealer v4, Factory Pro velocity stacks.
Justin is offline
post #9 of 13 Old 12-19-2014, 10:48 PM
davidmann's Avatar
I bought my bike with all shorts in it and I was thinking about installing the to taller ones in the middle to help mid& low range power. How much re tuning will I need to do?
davidmann is offline
post #10 of 13 Old 01-04-2015, 09:58 PM
davidmann's Avatar
so found out from factory Pro that using 4 short pipes has a negative effect on overall power so I put the to longer ones in the middle and now I have a set of velocity stacks for sale
I'll take your Factory Pro velocity stacks... racer155 Wanted: Buy or Trade 0 03-12-2009 02:53 AM
factory Pro Velocity Stacks?? sch2046 Performance and Tech 31 01-20-2008 09:57 PM
** F/S 04-05 Factory Pro Velocity Stacks ** Alien10 Parts, Gear and Accessories 8 09-21-2007 10:23 PM
factory pro velocity stacks oneradten Performance and Tech 26 02-09-2006 02:47 PM
Factory Pro Velocity Stacks BNninja Vendors deals 15 11-21-2004 12:19 PM
