F1 light - Kawasaki ZX-10R.net
post #1 of 19 Old 04-07-2009, 08:12 PM Thread Starter
tone.r's Avatar
F1 light
What makes that red f1 light stay on?
tone.r is offline
post #2 of 19 Old 04-07-2009, 08:46 PM
Starbucks Connoisseur
Static IP's Avatar
I just got that the other day. First time ever, I called a few dealerships and they say to bring it in and they have to hook it up to some diagnostic computer to see if it's the valves or timing or what.
One even told me to warm the bike up and ride it and turn it off and repeat it a few times and that sometimes makes it go away. Another said they can also reset it and it might help.
Can anyone chime in?
Static IP is offline
post #3 of 19 Old 04-07-2009, 09:17 PM
lyodbraun's Avatar
if its the red light on the right side of the dash its prob your oil light meaning a problem with the oil pressure
lyodbraun is offline
post #4 of 19 Old 04-07-2009, 09:22 PM
lyodbraun's Avatar
With the engine stopped and turned in the self-diagnosis
mode, the service code [A] is displayed on the LCD (Liquid
Crystal Display) by the number of two digits.
If the problem is with the following parts, the ECU can not
recognize these problem. Therefore, the warning indicator
light (LED), FI and/or immobilizer warning symbols do not
blinks, and service code is not displayed.
LCD for Meter Unit
Fuel Pump
Primary and Secondary Fuel Injectors
Stick Coil Secondary Wiring and Ground Wiring
ECU Power Source Wiring and Ground Wiring
post #5 of 19 Old 04-07-2009, 09:31 PM Thread Starter
tone.r's Avatar
Its not blinking or anything just staying on, is there a way to reset?
tone.r is offline
post #6 of 19 Old 04-07-2009, 09:33 PM Thread Starter
tone.r's Avatar
Originally Posted by lyodbraun View Post
with the engine stopped and turned in the self-diagnosis
mode, the service code [a] is displayed on the lcd (liquid
crystal display) by the number of two digits.
If the problem is with the following parts, the ecu can not
light (led), fi and/or immobilizer warning symbols do not
Lcd for meter unit
fuel pump
primary and secondary fuel injectors
stick coil secondary wiring and ground wiring
ecu power source wiring and ground wiring
thanks for the info
tone.r is offline
post #7 of 19 Old 04-07-2009, 10:14 PM
lyodbraun's Avatar
It also could be the the ignition switch, if ya put your bike in park the lights (city light tail light LP light) should come on if they dont then according to the 08's manual it says to replace the Ignition switch.. try that and see if those lights work.
post #8 of 19 Old 04-07-2009, 10:17 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
It's FI, F1 is a racing series.
Many reasons for it to be on, most commonly on from removing you exhaust valve servo, but it is similar to a Service Engine Soon Light on your car.
9R to 10R is offline
post #9 of 19 Old 04-07-2009, 11:00 PM Thread Starter
tone.r's Avatar
ok FI NOT F1 BUT I DO LOVE F1 RACING LOL CAN IT BE CLEARED LIKE IN A CAR? IT JUST CAME ON I HAVE SEEING IT ON.
tone.r is offline
post #10 of 19 Old 04-08-2009, 05:45 PM
smittyzx10r's Avatar
mine would come on because the exhaust valve switch under the rear cowl(which is disconnected) got stuck in the closed position.bumped in a few times,sprayed some wd-40,and it opens and closes now.no more fi light.
smittyzx10r is offline
Oil Light dimly light in rain storm?? fourtraxjay Performance and Tech 8 08-14-2008 10:30 AM
FI light on, no Neutral light. yammaxx The ZX-10R 12 05-28-2008 08:12 PM
FI Light fix ????? spidi511 The ZX-10R 7 05-10-2008 12:08 AM
F1 light!!!???? ali10r Performance and Tech 0 08-27-2006 01:04 PM
fi light reckless1 The ZX-10R 1 07-28-2006 10:30 PM
