F---in' Valves...WTF??? - Kawasaki ZX-10R.net
post #1 of 5 Old 05-06-2006, 04:38 PM Thread Starter
lenshead's Avatar
Here are the first 2 instructions form the section of the service manual titled:
"Engine Installation"
1) Support the engine with a suitable stand.
2) Install the heat insulation rubber plate.
Which basically says that I have to remove EVERYTHING just to get it out of the way so I can reach the valves unencumbered. This valve job is turning out to be such a royal pain I just may pony up the big bucks to pay a stealer next time...
Unfortunately I also have trust issues, as in did he actually do it, and do it the right way? Did he have any extra hardware left over?
Anyway, thanks for letting me vent.......
Thou Shalt Respect Thy 10, And Revel In It's Power, For It Is Good, And Plentiful.
lenshead is offline
post #2 of 5 Old 05-06-2006, 05:14 PM
If I remember correctly the rubber cover is looped over the "ears" of the radiator. Take the connectors off the radiator without messin' with the hoses and push the radiator out of the way a bit.
You don't need to drop the engine to adjust the valves although after I was done I thought it might be easier.
swjohnsey is offline
post #3 of 5 Old 05-06-2006, 08:30 PM
you could have just taken the top mounts out remove radiator and lean the engine foward.
http://aceperformance.com/
41 Land Speed record's 650 750 1000 1350 1650 2000 3000 3001+cc classes 236.96 MPH
Winner & fastest N.A. bikes of Texas Mile shootout N.A. and Nitrous class with NO NOS on bike.
223.33 MPH all motor Busa.
203 + MPH 2016 ZX10R
THE ICE MAN is offline
post #4 of 5 Old 05-07-2006, 12:02 AM
Shoot after you do it once you can have the motor on the floor in 30 minutes. I had mine in and out three times one week trying different cam timing numbers. It's really NOT all that bad, BUT the first time you'll take more shit off than needs to be.
Gunner is offline
post #5 of 5 Old 05-07-2006, 01:13 AM
RickRoush03's Avatar
you can ask the tech to tell you what each valve was spec'd at, Ivan did for me.
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
No exhaust? Bad on the valves? LOOK Loweredskulls Performance and Tech 10 02-13-2006 10:47 PM
Stainless Valves for ZX-10 Ryan Schnitz Vendors deals 8 02-09-2006 07:09 AM
ZX-10R BREAK-IN PERIOD KWAK10R Performance and Tech 146 11-20-2005 06:14 AM
Went to the dyno. now it will cost $1200 to fix WTF! 10 speed Performance and Tech 10 10-06-2005 01:39 AM
Vonstallin translator swft The Out House 7 11-20-2004 12:42 AM
