Extended Swingarms - Kawasaki ZX-10R.net
post #1 of 8 Old 12-29-2004, 08:11 PM Thread Starter
Extended Swingarms
I just sent a stock swingarm that I bought off of ebay to Spencer Cycle (Doug Ray) to have it extended. I'm a die-hard drag racer and just bought this ZX10R a week ago and already getting it ready for the upcomming season. I've got the lowering links,bought a stock seat from ebay and took the cover and foam off to get down lower, Mirror eliminators, Front end strap, Steering damper, 15/42 gearing, Power Commander USB, Akropovic full exhaust, and going to intall a Dry Shot of NOS here this weekend. Just wondering if anyone is making a lock-up clutch for this bike yet? I'm going to leave the head gasket alone because of using NOS. This will help keep the compression down. I will post pictures as the bike develops. Any help would be appreciated! Sincerely, Kenny Davis
ForceRecon is offline
post #2 of 8 Old 12-29-2004, 08:15 PM
MIA Post Whore
miykl's Avatar
Wecome and good luck. There's a few people considering the dry shot on the forum. Keep us posted with your results and experience getting it work.
miykl is offline
post #3 of 8 Old 12-29-2004, 08:39 PM
WOODYZX10R's Avatar
https://zx-10r.net/forum/showthread.php?t=4488
check out this video stock wheelbase turning low 9's
WOODYZX10R is offline
post #4 of 8 Old 12-29-2004, 08:54 PM Thread Starter
It looks like a snap! I've already been into the air box and decided where to mount the fogger. I've got several bike that I have a dry shot on. 02,ZX12R-03 Hayabusa, 02 GSXR-1000 motor stuffed into a 600 frame. The 600/1000 is my street racer. I run a 5lb. bottle that mounts in front of the tire and intimidates most anyone... The only problem I see with the 10 is mounting the Wide Open Micro Switch to the throttle linkage. It is in the middle of the throttle bodies and very tight fit. The air box was a real bitch to get out for the first time. I actually took a file and shaved off some plastic off of the sides to make it go back in alot smoother. Anyone installing a power commander will have to remove the airbox to get to those same wire connectors.
post #5 of 8 Old 12-30-2004, 11:25 AM
Ryan Schnitz's Avatar
Muzzys will be offering extended swingarms soon. Just incase anyone is interested.
They should have an air shifter kit out by spring too..
Ryan Schnitz is offline
post #6 of 8 Old 12-30-2004, 03:00 PM Thread Starter
Drag Stuff
Thanks Ryan! I'm looking for a air shift cylinder bracket much like what Doug makes at Spencer Cycle but for the zx10r. Not having much luck. I don't want to really tap the frame like I did back in the old days. I've got brackets for all my other bikes and would like to keep this one as clean. If anyone has already installed a air shifter on their bike please send me a Pic. I'd like to see any other options. I've already got all the stuff except the bracket itself. I just use a regulator fed from my NOS tank to feed the air shift system. It works great and saves space and no need for air tank in swingarm or extra bottle.
Ryan, I know most of the stuff you deal with Muzzy is pretty confidential. But have you tried any different clutch set up as far as Heavy springs, Clutch Stack height, etc.? I'm a very big guy 6ft. 255lbs. Heavy Hitter Club. I need all the help I can get!! Can't afford to smoke Crack!! Spend all my money on bikes and parts... Sincerely, Kenny Davis
post #7 of 8 Old 01-01-2005, 10:53 AM
I don't know of any brackets out there yet... but some should be out soon.
I always used stock clutch packs and springs. Never had any problems.
post #8 of 8 Old 01-01-2005, 10:28 PM
Certified SLOW
nolaZX10's Avatar
Good luck man, keep us posted.
nolaZX10 is offline
How much did you pay for your extended warranty? SacCityZ The ZX-10R 14 10-04-2004 02:39 PM
extended swingarm lzbrown The ZX-10R 3 05-24-2004 09:58 AM
