Gen 3: 2008-2010 Exhaust valve setup? - Kawasaki ZX-10R.net
post #1 of 6 Old 05-31-2011, 03:07 AM Thread Starter
Doyz's Avatar
Exclamation Exhaust valve setup?
Hi,
I have taken my r55 yoshi off my 09zx10 and re-installed the cat and stock exhaust, ran the cables back to the servo and put them on , i would like to no how to set up the tension properly is there an easy way i need some help with this. The servo turns but its straining because one side will be to tight, ive played around but it doesnt seem right . plz help
Doyz is offline
post #2 of 6 Old 05-31-2011, 03:36 AM
tasos's Avatar
Have you put them in the correct order?
The info (slack) is in the manual in Performance and Tech.
tasos is offline
post #3 of 6 Old 05-31-2011, 03:50 AM Thread Starter
Doyz's Avatar
yeah im pretty sure, it turns no worries just at the end or either way struggles seems like a fine tuning thing. I will look through the manual thanks for your help
Doyz is offline
post #4 of 6 Old 05-31-2011, 04:12 AM
tasos's Avatar
Also check pages 309 and 310
tasos is offline
post #5 of 6 Old 05-31-2011, 08:50 PM Thread Starter
Doyz's Avatar
hey guys ive checked the book and it doesn't give any description on how to adjust it just that, it must be done by an authorised kawasaki dealer....., id rather just set it up myself rip off going to them.
Doyz is offline
post #6 of 6 Old 05-31-2011, 11:58 PM
tasos's Avatar
Yeah it doesn't say anything... Assuming you did not change the order of the cables on the muffler side, i would give it alot of slack and tight it little by little. Also check that the servo bolt didn't move from it's position
tasos is offline
Tags
exhaust, servo, tension, zx10
Exhaust Valve Need it or Not? 2k7zx10 The ZX-10R 2 03-10-2011 12:50 PM
Exhaust butterfly valve aka exup valve position at idle zuhayr The ZX-10R 4 06-18-2010 05:07 PM
Exhaust Valve cesarb714 General Motorcycle Discussions 10 09-08-2009 01:07 AM
04 Exhaust Valve 10RKid Performance and Tech 8 12-02-2008 01:28 PM
what is an exhaust valve for? coastiepete Performance and Tech 52 11-28-2006 07:48 PM
