exhaust valve servo removal 08+ - Kawasaki ZX-10R.net
post #1 of 11 Old 08-13-2010, 08:11 PM Thread Starter
KIRK_ADAMS's Avatar
Has anyone removed the servo motor for the exhaust valve on 08+ 10's.....without buying the little plug from who ever sells it...???..Looking for a cheap DIY...dunno if a wire can be cut or a resistor put in...??
KIRK_ADAMS is offline
post #2 of 11 Old 08-13-2010, 08:17 PM
strkd50's Avatar
First off SEARCH BUTTON and as far as a DIY.....:headshakenot so much.
strkd50 is offline
post #3 of 11 Old 08-13-2010, 08:21 PM Thread Starter
KIRK_ADAMS's Avatar
it funny how you think I didnt search...I did....I searched for exhaust valve in the performance section AND the how to section...I did not find an ans to my question, so I posted this...
post #4 of 11 Old 08-13-2010, 08:28 PM
i attempted this just by wiring a few resistor and it didnt work after the bike reached 7k rpm. there is a thread on kawiforums about it. some guy posted a "working" schematic. i tried that schematic too, to no avail.
ivan sells them for 110$ I think
mityaz is offline
post #5 of 11 Old 08-13-2010, 08:51 PM
strkd50's Avatar
I searched around for a thread that me and a couple other members tested a few ideas out for it, and could not find it............so I retract my statement. The reason a simple fix will not work is that the PCM looks for a whole range of resistances in the motors "sweep", so it requires a little more technology than just a simple resistor. I recommend just removing the cables and any excess (tabs and what not) from the servo itself and just stash it out of the way.
strkd50 is offline
post #6 of 11 Old 08-13-2010, 08:56 PM Thread Starter
KIRK_ADAMS's Avatar
im really looking for a way to take it off without the $100 plug...im trying to take as much weight off the bike as I can...and im not using the exh valve....and yes, before anyone says it...I know it doesnt weigh much...but im taking ounces off from here and there to make this bike light as i can...im tight on money so the next best thing to do to a bike is weight off
post #7 of 11 Old 08-13-2010, 09:38 PM
bluedevil's Avatar
Well, it's only going to through an F1 light....for racing that should not be a problem to remove the servo it's not going to cause performance issues and you have a separate oil light for major problems. Someone did a how-to on this site but not going to try and find it, it's controversial and maybe illegal copying Ivans if that's what it is.
bloo
bluedevil is offline
post #8 of 11 Old 08-13-2010, 09:50 PM Thread Starter
KIRK_ADAMS's Avatar
so it doesnt throw the computer in any kind of safe mode if its unplugged and throws a code?
post #9 of 11 Old 08-13-2010, 09:55 PM
bluedevil's Avatar
not on the other Gens....it's for opening the exhaust valve mostly for emmisions/noise but no performance gains leaving it on or off....so basically it's not related to any type of ECU mapping...you should be good to go.
bloo
post #10 of 11 Old 08-13-2010, 10:00 PM Thread Starter
KIRK_ADAMS's Avatar
bloo
thank you much...off it comes!
WTB: Exhaust Valve Actuator Servo 04ZX-10R Wanted: Buy or Trade 2 09-02-2010 08:32 PM
Exhaust Servo removal? SAkI Performance and Tech 5 05-09-2008 07:41 PM
complete removal of exhaust valve servo if you have a full system? SpeedyCorky Performance and Tech 22 05-06-2006 04:46 PM
Exhaust Servo Motor Removal Question Larry Grogan The ZX-10R 1 02-27-2006 11:04 PM
Exhaust valve box removal??? on1whl Performance and Tech 5 01-25-2005 11:56 AM
