Exhaust Valve Actuator - Kawasaki ZX-10R.net
post #1 of 10 Old 03-31-2005, 11:30 AM Thread Starter
I called Ivan yesterday and he does have a working one and they will be ready in a few weeks. I am going to call tomorrow when I order my TRE and get a firm date...now we can remove that box and get no FI light.
BNninja is offline
post #2 of 10 Old 03-31-2005, 12:23 PM
unless the need is for space.. what is it hurting? i guess the pcIII could go there
MAVRIK is offline
post #3 of 10 Old 03-31-2005, 12:28 PM Thread Starter
exactly what i was thinking...i want my trunk space back!!!! I mean it will be a cheap little resistor like the TRE and then I wont get FI codes and can use my trunk again...plus that thing is a decently heavy box.
BNninja is offline
post #4 of 10 Old 03-31-2005, 12:38 PM
MIA Post Whore
miykl's Avatar
....plus hearing the actuator at start up is just a little annoying reminder that i could not remove a part that was serving no purpose. Ivan will be recieving some more of my $$$ fo sho.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #5 of 10 Old 03-31-2005, 12:56 PM
i think with a slip on that people found that leaving the servo was better..right?
MAVRIK is offline
post #6 of 10 Old 03-31-2005, 12:59 PM
MIA Post Whore
miykl's Avatar
Me no know, no care! Me full system suckas!
..personally, I preferred it disconnected with the slip on.
2004 636 track
miykl is offline
post #7 of 10 Old 03-31-2005, 10:21 PM
I took my stock can and mid-pipe off today, and the exhaust valve was sitting open. I thought it was supposed to be closed until 5,000 RPM. My Akra slip-on sounds pretty loud at lower RPM. Could my valve be stuck open?
Cryptoman is offline
post #8 of 10 Old 03-31-2005, 11:09 PM
Post Whore
El Diablo's Avatar
It closes when the switch is turned on and the actuator cycles...
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #9 of 10 Old 04-01-2005, 07:03 AM
correct-a-mundo el
MAVRIK is offline
post #10 of 10 Old 04-01-2005, 07:54 AM
So it reopens when you turn the switch off? There is still power to the ECU and actuator after you turn the ignition off?
How to disconnect exhaust valve... w/pics>>> El Diablo Performance and Tech 107 02-15-2011 01:49 AM
Why disconnet exhaust valve Greenhornet Performance and Tech 24 03-30-2005 08:02 AM
How to disconnect Exhaust Valve w/pics>>> El Diablo How To... 1 03-13-2005 02:11 AM
Exhaust valve box removal??? on1whl Performance and Tech 5 01-25-2005 10:56 AM
Exhaust Valve & Control box (yes again) vane The ZX-10R 8 01-25-2005 03:30 AM
