Exhaust heat shield removal on 06-07 - Kawasaki ZX-10R.net
post #1 of 8 Old 08-04-2008, 04:51 AM Thread Starter
greenman43's Avatar
Images: 33
Wondering if any of the racers have removed this shield, and if so, have they noticed any problems (ie. damage to the plastic undertray, or problems with the electrics due to heat soak) ?
For clarity, I'm talking about the thin metal plate bolted to the underside of the tray, and not the piece that sits next to the master cylinder.
Thanks in advance,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
post #2 of 8 Old 08-04-2008, 05:25 AM
KuDaMaStA's Avatar
i would think that it is there for a reason. Not sure what would happen.
KuDaMaStA is offline
post #3 of 8 Old 08-04-2008, 05:48 AM Thread Starter
greenman43's Avatar
Images: 33
Not sure if it's its necessary when the bike is running at speed, perhaps there would be sufficient airflow under there to wick away the heat. Guess I'll find out soon enough :)
Cheers,
Brian
post #4 of 8 Old 08-04-2008, 06:03 AM
KuDaMaStA's Avatar
post back and let us know how it worked. If nothing happens I will probably remove mine.
post #5 of 8 Old 08-04-2008, 06:16 AM
SkyDork's Avatar
Just out of curiousity, what are you trying to accomplish by removing it? Given that the airflow in that area is very disturbed, it's possible that a vaccuum is created in that area that traps the heat from the exhaust and makes it even hotter there. But the real reason that plate is there is to prevent cooking the battery and has little to do with the plastic deforming or melting.
I say leave it alone.
#WordCrimes
SkyDork is offline
post #6 of 8 Old 08-04-2008, 06:56 AM Thread Starter
greenman43's Avatar
Images: 33
Just taking a bit of weight out, Jeff (201g, actually). I installed an Akrapovic system last weekend, and noticed that the heat shield looked a bit out of place. Looking at a pic of an All-Japan Superbike, I saw that it didn't have one, so I've taken mine off. Will report back on anything noticeable.
Cheers,
Brian
post #7 of 8 Old 08-04-2008, 07:12 AM
SkyDork's Avatar
Cool, I hope it works out. I would suspect that you will not notice anything right away with that mod, but it may actually shorten your battery life a bit from the high heat. You may be able to find some of that thermal adhesive tape and mount it under the battery but inside the tray. That might help keep the temps in-check under the seat, but keep the weight off and not have that silver plate visible from the back. Those batteries are expensive!
#WordCrimes
SkyDork is offline
post #8 of 8 Old 08-04-2008, 08:35 AM Thread Starter
greenman43's Avatar
Images: 33
Thanks Jeff, exactly what I was thinking. I've got a sheet of that insulation waiting to be put on, just not quite enough so got to track down a bit more.
All the best,
Brian
exhaust heat shield demented racing The ZX-10R 10 05-25-2008 12:55 PM
Exhaust Heat shield superman10r Wanted: Buy or Trade 2 11-27-2007 05:52 PM
Stock exhaust heat shield Macatoni The ZX-10R 1 06-17-2007 05:18 AM
Needed Black exhaust heat shield Jeckylll Wanted: Buy or Trade 2 05-04-2007 11:20 AM
exhaust heat shield/ fender eliminater 06'10rPilot The ZX-10R 10 11-21-2006 12:28 PM
