exhaust flapper motor removal - Kawasaki ZX-10R.net
post #1 of 19 Old 12-03-2009, 02:37 AM Thread Starter
i just replaced my stock exhaust with an evo akra exhaust system, now i would like to remove the flapper motor totally, naturally this gives me an error message........ now i know with my GSX R we just removed one of the PINS on the ECU main plug and the pblm was gone. does anybody here know whether this works on the ninja and which pin must be removed ???
it's a 2009 ninja zx10r thanks in advance...........
MarcelZX10R is offline
post #2 of 19 Old 12-03-2009, 02:58 AM
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
i'd love to find a solution for this as well, as far as I know, there isnt any. I do know that when you remove the smog pump (AIS) , you can remove the error code by jumping the sensor plug. Hopefully someone has a fix for this
spikespiegel is offline
post #3 of 19 Old 12-03-2009, 03:03 AM Thread Starter
on the gsx r 1000 i just pulled a pin out of the ECU main plug...... and the err message disappeared, i guess this must work on the ninja, but which is the correct pin ???...... and yes it's the sensor cable which needs to be unplugged.....
post #4 of 19 Old 12-03-2009, 09:42 AM
strkd50's Avatar
The only way to remove the motor without a FI light ist to get the Servo Eliminator from Ivan's Performance. Several members including myself have tried fooling the ECU other ways, but havent found one that works just yet.
2012 ZX-14R
#228
strkd50 is offline
post #5 of 19 Old 12-03-2009, 09:45 AM
themightymezzo's Avatar
I believe this is the general consensus.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #6 of 19 Old 12-03-2009, 10:10 AM Thread Starter
arrrgghhhh why did i ever sell my gsx r......lol no the tears are long gone, at least after the frist ride at full rpm's on the ninja ...... o.k. than anybody has a link for that servo eliminator ? sorry don't know who's ivan.......
post #7 of 19 Old 12-03-2009, 10:42 AM
Quick10's Avatar
http://www.ivansperformanceproducts.com/
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #8 of 19 Old 12-03-2009, 10:49 AM Thread Starter
thks man
post #9 of 19 Old 12-03-2009, 10:57 AM
Ninja187's Avatar
A race ECU also works, about the same price as a power commander just harder to find someone who can tune. I pulled all that junk close to two years ago and no issues. I go my ECU and harness from Advanced kawasaki http://getakawi.com/ for about $400
GEN 4: Brembo HP calipers, Brembo HP T-Drive Rotors, Brembo RCS master cylinder, Fren Tubo SS lines, re-valved Ohlins damper, Ohlins TTX shock, Yoshimura case covers/frame sliders, Yoshimura 3/4 R77D Ti exhaust, BMC filter, Puig DB, Renthal Clip ons/sprockets, attack rearsets, Guhl flash, kawi kit throttle, Ballistic EVO2 8 cell, Annitori RL quick shifter, Dunlop rubber.
Ninja187 is offline
post #10 of 19 Old 12-28-2009, 08:39 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Jeezus Christ, the servo motor eliminator is $110. . .
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
Power valve motor removal morefire The ZX-10R 16 08-19-2008 11:02 PM
Exaust Valve Motor removal... KaTooM Performance and Tech 2 07-12-2007 10:46 AM
tricking ex. flapper control ninjafreek Performance and Tech 1 02-23-2007 11:02 AM
Exhaust Servo Motor Removal Question Larry Grogan The ZX-10R 1 02-27-2006 10:04 PM
Flapper in stock exhaust Auron Performance and Tech 14 12-20-2005 10:53 AM
