Exhaust butterfly operation - Kawasaki ZX-10R.net
post #1 of 2 Old 08-21-2010, 10:57 PM Thread Starter
Can someone please explain to me how the exhaust butterfly operates? I'm having some main relay issues and unhooked the exhaust servo cables under the impression the butterfly fails to the open position. But I noticed that when you give it gas it pulls the aft cable out. If it does truly fail to the open position then as you give it gas it closes? Is this correct?
windycityblues is offline
post #2 of 2 Old 08-21-2010, 11:41 PM Thread Starter
Nevermind. Did a little more digging and found it does indeed close gradually until around 7k rpm where it opens again.
Code 34/exhaust butterfly 2nd gen Sasquatch Performance and Tech 5 05-04-2010 03:23 PM
Exhaust Butterfly Valve Actuator 07oaklandZX10R The ZX-10R 8 03-18-2010 07:06 AM
the exhaust butterfly motor?? bgmagma10 The ZX-10R 16 08-04-2009 12:36 PM
Exhaust Butterfly Valve Actuator lespaul66 The ZX-10R 6 03-26-2006 07:49 PM
Exhaust Butterfly livnpaintball Performance and Tech 9 01-29-2005 12:33 AM
