Exhaust Butterfly - Kawasaki ZX-10R.net
post #1 of 10 Old 01-25-2005, 11:31 AM Thread Starter
Exhaust Butterfly
Any One Tried To Remove The Butterfly And Shaft That Is In The Stock Header? And If So Any Numbers On The Hp Scale?
livnpaintball is offline
post #2 of 10 Old 01-26-2005, 12:02 AM
The side where the cables connect to the valve, the shaft is only kept in place by to spot welds on the headers. Problem is, to reweld the Ti if you do loosen it there to remove the shaft. You cannot remove the butterfly as a whole, as the headers get smaller toward the back! Only option is to drill/ grind it out with something! But then you'll have a 3mm hole on the inside of your headers that need to be blocked up!
vane is offline
post #3 of 10 Old 01-26-2005, 06:55 AM Thread Starter
thats not a problem just wounder if anyone has done it yet...
post #4 of 10 Old 01-27-2005, 04:05 AM
No one around here that can re-spot the Ti
vane is offline
post #5 of 10 Old 01-27-2005, 01:53 PM Thread Starter
I just planned on tapping the hole and sticking a plug in it.
post #6 of 10 Old 01-27-2005, 02:08 PM
MIA Post Whore
miykl's Avatar
Come on! Be a coonass! Fill with JB Weld!
miykl is offline
post #7 of 10 Old 01-27-2005, 03:37 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
With it dissabled, the valve is open. I wouldn't think it would be worth it to go to all that trouble to possible ruin you exhuast, for IMO nothin. If you want more HP, go with an aftermarket.
Or bust out you cat. and take the cables off the deally under the rear seat.
JMHO.
James 3:7,8
hillcountry10r is offline
post #8 of 10 Old 01-28-2005, 06:19 PM
wstaab's Avatar
You will need to cut the exhaust butterfly in half to remove it. A plasma torch is the best tool to cut it. Remove the shaft and weld the hole with a TIG welder and Ti rod. No HP gains but does smooth the torque curve between 5k to 9k rpm vs just disconnecting the cables.
http://photopile.com/photos/wstaab/ZX10R/168799.jpg
wstaab is offline
post #9 of 10 Old 01-28-2005, 11:30 PM Thread Starter
thats what I was hoping for,, thanks wstaab. I wanted to hear from someone who's done it before me.
post #10 of 10 Old 01-28-2005, 11:33 PM Thread Starter
i might use aircraft grade epoxy, not a bad idea.
Effectiveness of an aftermarket exhaust and/or PCIII MAVRIK The ZX-10R 10 07-09-2010 02:31 PM
anyone familiar with hmf exhaust youngballer The ZX-10R 18 06-10-2006 01:40 AM
Exhaust valve box removal??? on1whl Performance and Tech 5 01-25-2005 10:56 AM
SpencerCycle ZX10R Exhaust Hanger- New Product Release SpencerCycle.com Parts, Gear and Accessories 13 06-30-2004 08:54 AM
Hotbodies undertail exhaust Vonstallin The ZX-10R 2 05-19-2004 09:39 AM
