EvoII can question.. - Kawasaki ZX-10R.net
post #1 of 10 Old 07-31-2005, 07:24 PM Thread Starter
I know the II can has a fat outlet, but according to akros website,to the best of my research, they list the inlet as the same size? is that right? it kinda looks like they list the outlet the same size too.. so if thats correct, a guy with a evoI system could just order the evoII shorty can. am i correct?
Catfish_ is offline
post #2 of 10 Old 07-31-2005, 08:10 PM
MIA Post Whore
miykl's Avatar
I'm pretty sure both the inlet and outlet are both larger on the II than the evo I. I can measure if needed.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #3 of 10 Old 07-31-2005, 09:15 PM
i bet they are both 2"
BNninja is offline
post #4 of 10 Old 08-02-2005, 07:13 AM
The inlet on my EVO1 can is 2.375 inches. I would think the EVO1 and EVO2 inlets are the same size, just the length of the can is different. They might be interchangeable.
BIKEMIKE is offline
post #5 of 10 Old 02-09-2006, 10:10 PM
yehzx10r's Avatar
Anyone get to the bottom of this? Will the evo2 can fit on the evo1 system?
WERA #74
yehzx10r is offline
post #6 of 10 Old 02-09-2006, 10:12 PM
i think it will
oneradten is offline
post #7 of 10 Old 02-10-2006, 03:22 AM
yehzx10r's Avatar
Response I got from Akrapovic on this topic...
"Dear Jon,
the muffler for ZX10R 2005 from our EVO II exhaust system will fit the exhaust system (link pipe) from
our EVO I series. Both mufflers have the same inlet hole diameter, but you should consider noise levels which are
greater from those in EVO I axhaust system.
Please visit our web site for additional information.
Best regards
Akrapovic R&D team"
So it looks like it WILL fit.
WERA #74
yehzx10r is offline
post #8 of 10 Old 02-10-2006, 07:14 AM
Post Whore
Sgtusmc96's Avatar
Inlets are the same but not sure about the exit. My Evo I canister fit perfect on the header I got from you Miykl.
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #9 of 10 Old 02-10-2006, 10:58 AM
Rspec99's Avatar
Images: 11
Inlet is definitely the same, but outlet is bigger on the EVO2
Rspec99 is offline
post #10 of 10 Old 02-10-2006, 06:09 PM
grego10r's Avatar
cut the evo 1 can and you have evo2 can daaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
04 zx10r 14 vmax
grego10r is offline
oil question zfactor2004 Performance and Tech 16 07-21-2005 08:21 PM
PC USB new install question 10rider Performance and Tech 3 06-05-2005 11:38 PM
Difference between EvoI and EvoII? heavyd Performance and Tech 10 05-19-2005 09:39 AM
A Question for you Brains out there - calling all PC3 nerds.JK GREENDEL Performance and Tech 2 04-23-2005 07:13 PM
Akra EvoII can on an EVO I system??? on1whl Performance and Tech 3 03-29-2005 09:17 PM
