EVO II Installation - Kawasaki ZX-10R.net
post #1 of 2 Old 01-02-2009, 03:22 AM Thread Starter
vagearhead's Avatar
EVO II Installation
I'm going to be installing an EVO II system on my bike. I've put plenty of exhausts on different bikes before but never on the ZX-10. I'm looking for any of those little tips and tricks regarding fitment...etc which help make the job a breeze instead of a headache.
Does anyone have a torque spec handy for the header bolts?
Also, any recommendations on where online to get new flange gaskets cheaper than at the dealer?
Thanks!
vagearhead is offline
post #2 of 2 Old 01-02-2009, 10:54 AM
La Flama Blanca
9R to 10R's Avatar
Images: 102
They are torqued to 12ft lbs, but they will back off if you torque them that low, best to snug them up the best you can, I found a combination wrench can actually get you in to all the bolts with a little dexterity, and not having to remove the radiator, then, and this is imperitive, make sure you check those nuts again after riding a while, 99% of the time they loosen up at least once.
You would probably be OK using the gaskets again( if you have too, would not reccomend it), but I swear my EVO II system came with new ones, or maybe that was my Beet, etiher way, I had a extra set I think. But if I remember they were like 3$ a piece from Ron Ayers. Good Luck. And its a piece of cake install, you can get by without removing the Radiator if you choose.
9R to 10R is offline
Clip-on Installation afskypilot The ZX-10R 8 03-28-2008 10:34 PM
Wrong T.R.E. Installation kawaboy Performance and Tech 2 07-29-2007 11:55 AM
Superbike bar installation! Superbike1 Performance and Tech 49 03-20-2007 08:01 PM
Evo II Installation MILLENNIUM FALCON Performance and Tech 1 03-19-2005 09:28 PM
TRE installation help..... Ground Zero Performance and Tech 15 10-05-2004 05:27 PM
