Euro spec Gen2 lambda sensors question - Kawasaki ZX-10R.net
post #1 of 3 Old 07-01-2012, 01:54 PM Thread Starter
Gen2 Ripper
neverendingmods's Avatar
What is the thread size and pitch of the lambda sensors in the mid pipe? I lost both bolts from my delkevic mid pipe and it was a giant pita to find them originally. Delkevic does not supply those bolts to us in US and our bikes don't have lambda sensors.
I had to take it to hardware store before I had it on bike and that is not an option as its on bike.
Really need help on this.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #2 of 3 Old 07-01-2012, 03:50 PM
Supercharged Mod
There are 2 types of industry-standard lambda sensor threads "big" and "small". The standard automotive heated sensor is the "big" variety and it is M18x1.5. If that doesn't look anywhere close to being correct, it is M12xsomething but I don't know the pitch.
GoFaster is offline
post #3 of 3 Old 07-01-2012, 06:12 PM Thread Starter
Gen2 Ripper
If the "BIG" style you mean same as a wide band sensor/oxygen sensor size than they are definitely the "small". And that is the problem. They are a VERY odd pitch.
Screw it, I am just going to use Copper high temp liquid gasket to fill in the holes along with a bolt that will just barely fit inside the threaded holes. that way the liquid gasket doesn't blow out and the bolts will be held in by the liquid gasket. All easily removable and not permanent and no cross threading involved.
I had to cut down and hand file the previous bolts I had found at the 3rd hardware store I tried. The bolts were 4" long and only need 1.25-1.5" length. Any longer and they interfere with the exhaust flow by being too far down. Wait a pain in the ass!! Stupid holes.
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
Gen 4: Euro Spec ECU carnivor32 The ZX-10R 2 02-18-2012 08:24 PM
Wow: 2011 dyno; euro vs US spec hesaves0211 The ZX-10R 34 11-23-2011 09:55 PM
Mod to default ECU to Euro spec maps lil ninja Performance and Tech 5 06-02-2009 07:35 AM
US to Euro spec Cling The ZX-10R 8 11-24-2007 08:29 AM
Boz Bros & Lambda Sensors bkkninja Performance and Tech 15 04-04-2007 09:01 PM
