Gen 4: 2011-2015 ESD light when head/tail lights are removed - Kawasaki ZX-10R.net
post #1 of 1 Old 11-02-2018, 11:03 PM Thread Starter
Hi all, just took my 2014 Gen4 to the track for the first time, second owner. I took it for a ride the first time at the track with no head/tail lights and after moving up to about 10-15 mph (sometimes earlier, sometimes later) the yellow FI light would come on, and the ESD light on the dash would come up. Sometimes I would notice, it would sound like the servo was spazzing out in the damper when I got done with my session (Or maybe it was the rectifier/regulator buzzing, not sure).
When I got home, I reconnected the lights, rode around, no problems. When I again removed the headlight fuse, and disconnected the tail light, the light would cut on again after a little bit of riding. Has anyone else experienced these issues? I've done some searching and haven't seen anything about this specific issue. My battery voltage is good, and doesn't really change much with or without the headlights on ( reads about 14.5-14.6 when the bike is running at idle while cold).
Gromasaki Rider is offline
Tags
esd light, fuse, headlight, trackday
Gen 4: ESD light when head/tail lights are removed Gromasaki Rider The ZX-10R 5 11-05-2018 06:51 AM
Esd light after pulling light fuses Snakes709 The ZX-10R 0 05-30-2016 01:53 PM
I Need A Integrated Tail Light Gen 1 & Tail Light Harness Plug hellsrazor Wanted: Buy or Trade 2 04-28-2013 08:13 PM
no tail lights or brake lights ??? "HELP" BAYBOI Performance and Tech 12 09-19-2011 08:19 PM
Adding switches to head-lights and running lights Petrus Performance and Tech 1 06-18-2010 11:15 AM
