Error code 25 - Kawasaki ZX-10R.net
post #1 of 14 Old 04-03-2009, 02:05 PM Thread Starter
Error code 25
Can anyone help me identify the error with code 25? The bike runs fine as has no loss of power but I am getting some sort of error since the FI light keeps flashing. And the error code is 25, what error is this?
2K6-ZX10R is offline
post #2 of 14 Old 04-03-2009, 02:23 PM
LaurenOE's Avatar
Send a message via AIM to LaurenOE
On a 2008 ZX10R, Error code 25 is the gear position switch. "If the gear position switch system fails, (no signal, wiring short or open), the ECU sets the top (6th) gear position."
LaurenOE is offline
post #3 of 14 Old 04-03-2009, 02:34 PM Thread Starter
Oh I forgot the bike is a 2006 model. But actually the light came on the instant I put it into first gear, so it might be something like that. Does anyone know if error code 25 means the same on 2006 as the 2008?
post #4 of 14 Old 04-04-2009, 02:13 AM
sextaafondo's Avatar
Yes, it is.
G.P.S. error.
sextaafondo is offline
post #5 of 14 Old 04-08-2009, 05:49 AM Thread Starter
Could one of you provide me with info on where to find this GPS sensor and maybe with a picture to illustrate?
post #6 of 14 Old 04-08-2009, 09:13 AM
tasos's Avatar
Here
ID:	92944   Click image for larger version
tasos is offline
post #7 of 14 Old 04-08-2009, 09:18 AM
tasos's Avatar
The actual sensor is on the first page, on the third picture under the chain.
Remove it, clean it and put it back. If it's still not working, check the connection wire on the throttle bodies /replace sensor(second page, first picture -C-). Hope this helps.
tasos is offline
post #8 of 14 Old 04-10-2009, 05:45 AM Thread Starter
Thank you so much. That was very very helpful, i will try that and see if it helps. Will it harm the bike to drive with a broken GPS sensor? It feels like it deliveres full power, and as i understand the bike will think it is in 6th if the sensor is not working and therefore i must get a richer a/f than else in the lower gears which will not be as harmfull as a lean mixture, but i might be missing something?
post #9 of 14 Old 04-10-2009, 06:17 AM
tasos's Avatar
Glad to help . It's better to fix/replace it. Richer mixtures can cause damage too (higher temps etc). Maybe it needs some cleaning, this is a "critical" sensor, if it was totally gone the bike wouldn't start.
tasos is offline
post #10 of 14 Old 04-10-2009, 06:23 AM
Send a message via Yahoo to wildcats
damn he did everything but do it for ya lol good shit
wildcats is offline
error code 63 '05 10R Tailgunner Performance and Tech 7 06-17-2009 10:20 PM
FI error code 34 ash01s2001 Performance and Tech 10 11-03-2008 07:58 PM
Error Code 62 afskypilot Performance and Tech 2 04-19-2008 01:37 AM
kawi race ecu error code question 10rmotor Performance and Tech 8 01-08-2007 11:15 AM
