Gen 3: 2008-2010 Engine temp and speed sensor signal @ the ECU?? - Kawasaki ZX-10R.net
post #1 of 6 Old 09-18-2012, 06:57 PM Thread Starter
ke2012's Avatar
Good evening all,
3rd GEN
Anyone know what wires going into the ECU(color and color stripe) are the engine temp and speed sensor wires. Need them to input into my PCV, and trying not to run wires front to back if i can avoid it. If not, i have the speed wire coming off the tach alread labeled but not sure what wire sends the temp signal coming off the temp sensor on the back of the head. Any help would be appreciated...more than likely they are the same on gen 1-3.
thanks
ke2012 is offline
post #2 of 6 Old 09-18-2012, 09:50 PM
thundercoupe9's Avatar
speed sensor blue/yellow #12
water temp sensor Orange #25
thundercoupe9 is offline
post #3 of 6 Old 09-19-2012, 07:07 AM Thread Starter
ke2012's Avatar
Thank you
ke2012 is offline
post #4 of 6 Old 10-14-2012, 09:47 PM
What do you have in place for your readings? I have even trying to set my temp but it shows me -160 to -230. I was wondering if you could share what your inputs are for you temperature and voltage.
Sent from my iPhone using MO Free
mathom33 is offline
post #5 of 6 Old 10-15-2012, 09:16 PM Thread Starter
ke2012's Avatar
Kind of hard to explain, but its a matter of the Guage set up.
ke2012 is offline
post #6 of 6 Old 10-15-2012, 11:12 PM
I true using a multimeter to take voltage readings and match them to the bikes temperature it was displaying in the gauge. The voltage was jumping all over the place. I had issues with my PCV, so DJ swapped them out for me since it was under warranty. The first one was spot on with the temp. This one wasn't anywhere close, and the more I mess with it the worse it gets.
mathom33 is offline
Gen 1: Water temp sensor Greenzx10 Performance and Tech 6 04-16-2012 10:08 AM
Speed sensor signal wire (gen 3)? Luiz_Direito General Motorcycle Discussions 9 04-03-2012 09:25 AM
Gen 3: 3rd gen speed sensor signal...where to tap?? ke2012 Performance and Tech 3 10-18-2011 08:01 AM
water temp sensor threads leemille Performance and Tech 0 11-26-2009 05:03 AM
Need an air temp sensor for 04-05 zx10r greencheezeeta Wanted: Buy or Trade 3 04-16-2008 07:26 AM
