Engine out, what parts should I replace? - Kawasaki ZX-10R.net
post #1 of 4 Old 07-21-2007, 08:36 PM Thread Starter
Rizzo's Avatar
Hey guys,
My engine will be coming out very shortly and the lower cases and bearings are being replaced for warranty.
Just wanted to check if there is anything else I should replace inside the engine for piece of mind while this is getting done, instead of having to do it a little bit further down the track, eg. retainers, cam chain tensioner etc? I dont really know to much about engine insides and what I should be replacing, these examples are just what I can remember from other posts.
When this happens I already will be degreeing cams, thin head gasket, and race intake cam, bike already has all the other bolt on fast bits.
Thanks
Rhys
Rizzo is offline
post #2 of 4 Old 07-22-2007, 11:24 PM
dsabat's Avatar
Nothing in particular. Your service tech will tell you what he wants to replace. If the crank bearings were toasted you may want to replace your oil pump, also the oil pickup screen for sure, but probably they are planning this already. It's worth it to check the thickness of your clutch fibers, but again the wrench should do this without prompting. good luck, Dean
dsabat is offline
post #3 of 4 Old 07-23-2007, 03:04 AM Thread Starter
Rizzo's Avatar
Thanks for that
There replacing the lower cases because I was unlucky and ended up with a porous casting. I had a very small leak of coolant when bike was really hot just behind number 1 cyclinder on the lower case, a small drop would appear straight out of the metal. Anyhow dealer has been very helpful taking care of it.
Rizzo is offline
post #4 of 4 Old 07-23-2007, 08:50 AM
jtemple's Avatar
Funny you should mention that. I had the exact same problem in my '05 Ti. The dealer and Kawasaki both told me to go pound sand, even though the bike was less than 2 weeks old. It was a Kawasaki demo bike with 4000 miles on it. It had never been titled. I bought it as-is. No warranty, no assistance!
jtemple is offline
looking to replace grips.... BornSinner Performance and Tech 10 11-23-2006 05:17 PM
Wanted: 04/05 ZX10R motor or Engine parts Mavspire Wanted: Buy or Trade 1 08-20-2006 10:34 PM
02 Nissan Engine Altima parts fastburnzx-10 Garage Sale 15 03-30-2006 09:56 PM
Engine and other OEM parts needed! ! ! Suix Wanted: Buy or Trade 27 06-20-2005 10:42 PM
Clip ons??? anyone replace the clipons yet?? Vonstallin The ZX-10R 0 07-20-2004 02:51 PM
