Engine oil on tire - Kawasaki ZX-10R.net
post #1 of 9 Old 08-20-2008, 11:40 PM Thread Starter
cueman's Avatar
Engine oil on tire
I got the rear tire soaked in motor oil when i cracked my case.
Does the oil soak thru and just resurface are can i scuff it and dosome burn outs and still use the tire?
04 ZX10 muzzy turbo,ported and polished head,carpenter valve springs and valves,kaw race cam,walbro fuel pump,begi fmu,mps airshifter,pcIII and ignition module,strectched 10 over,galfer brake lines,530 ek drag chain,16 front sprocket 45 rear sprocket,gpr dampner,modded clutch basket
cueman is offline
post #2 of 9 Old 08-20-2008, 11:44 PM
JUPJON's Avatar
Location: Fargo, ND (only about 6 month riding season unfortunatly)
Images: 15
Its hard to say depends on the tire and if you cleaned if off right away. I would get the oil leak fixed and take it easy on the tire and just test it out? Most tires are fairly well resistant to chemicals and such.
98% of all Harleys ever sold are still on the road. The other 2% made it home.
JUPJON is offline
post #3 of 9 Old 08-21-2008, 10:43 AM
La Flama Blanca
9R to 10R's Avatar
Images: 102
The oil will soak into the tire, get rid of the tire, ask yourself, is it better to pay for a 135$ tire now, and be safe or be sorry later and pay for severl hundred dollars in bodywork.
9R to 10R is offline
post #4 of 9 Old 08-21-2008, 10:48 AM
Supraman78's Avatar
Images: 11
do a bigassss burn out and get rid of the tire...hehe at least it will make you feel better
05 ZX-10R Green *SOLD* - Champs Frame Sliders, Swingarm Spools; Clear Alternatives Integrated Taillight; Clear Euro Signals; H7 Silverstars ; 1/5th Throttle Mod; Ivan's Block Off Plates; Hyperpro Steering Damper; OEM Solo Seat Cowl; Hindle Ti High Mount Exhaust shortened 4 in; SuperLED green running lights, LEDMods.net Green Speedo; GIPro gear indicator w/ TRE
Supraman78 is offline
post #5 of 9 Old 08-21-2008, 01:09 PM
Big Daddy's Avatar
Images: 38
this is correct
Big Daddy is offline
post #6 of 9 Old 08-21-2008, 01:15 PM
chogue's Avatar
Images: 13
i vote for coating the underside of the bike with WD 40 so the rubber wont stick, then doing a crazy ass burn out. dont forget to post the video on you tube
chogue is offline
post #7 of 9 Old 08-21-2008, 01:28 PM
Best advice so far!
cyp-ninja is offline
post #8 of 9 Old 08-21-2008, 04:22 PM
I just got my rear tire soaked for the 2nd time thanks to my oil pan breaking, looks like a smokey burnout is in my near future!
ExtendMy10R is offline
post #9 of 9 Old 08-22-2008, 07:48 AM Thread Starter
cueman's Avatar
Thanks everybody im replacing tire i launched it at 3000 rpm and spun the tire the turbo wasnt even starting to boost.
cueman is offline
Tire Warms Vs Tire socks Gang Green Performance and Tech 3 06-21-2008 11:02 AM
Tire Review: Dunlop N-Tec DOT rear race tire wsmc27 Track 4 08-09-2007 03:14 PM
Best way to clean a rashed engine cover engine? Suzuk1ki11a Performance and Tech 4 06-06-2007 01:38 PM
Would you feel safer on a Z(W) tire or a Z(Y) tire? Grease The ZX-10R 15 04-30-2007 01:10 PM
Monting rear tire without tire machine? blackisfaster Performance and Tech 9 04-24-2007 01:28 PM
