Gen 4: 2011-2015 engine noise - Kawasaki ZX-10R.net
post #1 of 3 Old 06-05-2013, 07:49 AM Thread Starter
engine noise
My engine seems to have alot of ticking and knocking. It seems alot noisier than my old zx9. The bike only 600 miles on it and I haven't took over 9k rpm. I'm wondering if the gen 4 engine is just a noisier engine because of the higher compression or should I have it looked at? Gets more noticeable at higher rpm.
emc05 is offline
post #2 of 3 Old 06-05-2013, 08:22 AM
willieswonka06's Avatar
Images: 18
Mine makes some valve train noise. Heard its perfectly normal. Runs hard. How many times have u changed the oil?
"Only ride as fast as your guardian angel can fly"
willieswonka06 is offline
post #3 of 3 Old 06-05-2013, 08:41 AM
SkyDork's Avatar
Well, is it ticking or is it knocking? Two completely different things.
If it's ticking, it will quiet down a bit after the cam chain tensioner is able to take up the slack after more miles. Completely normal. If it's knocking, then fill it with premium gas and if it's still knocking after that, get it towed to the dealership. Don't ride it there.
#WordCrimes
SkyDork is offline
04 engine noise gsxrche The ZX-10R 4 06-26-2011 06:43 AM
excessive engine noise 08zx10rny Performance and Tech 13 08-16-2010 02:51 PM
Engine Noise! Help!! FreshZX10 Performance and Tech 9 03-05-2009 12:49 PM
Engine noise. Dazza71 The ZX-10R 3 09-02-2007 10:06 AM
05/06 engine noise comparison Sands The ZX-10R 26 06-01-2006 08:45 AM
