Engine markings - Kawasaki ZX-10R.net
post #1 of 3 Old 10-23-2010, 05:28 PM Thread Starter
keithk's Avatar
Engine markings
I was reading a post on the markings or dots on the side of the crankcase, so I checked mine and it had 1 dot. What does that mean? What is the difference between a motor with no mark and a motor with 1 mark or 2?
keithk is offline
post #2 of 3 Old 10-23-2010, 05:42 PM
NinjeR's Avatar
It just marks telling you which model it is...apparently, they made a few versions of the same motor with mild variations, if that makes any sense.
NinjeR is offline
post #3 of 3 Old 10-23-2010, 05:44 PM
NinjeR's Avatar
Quote taken from Tasos, he knows the most about these markings. Get a hold of him if you need more info.
QUOTE
In 04 Kawi [email protected] up with the crankcases, they were not identical, my guess because they were too soft. The 04 engine was a close to a race engine you could get at the time.
They had 3 different types. So they had to produce 3 different types of cranks, clutches and generator gears. Basically their gears so everything lines up inside the engine. The crankcases have these marks. The clutch,generator gears and crank have letters-or no letter. (The clucthes also have a letter which indicates the year, 1 is 04, 2 is 05).
It is very important to know your engine's configuration when you are replacing parts.
You only need to know the crankcase marking "hole" and clutch letter to find the rest from the manual chart.
NinjeR is offline
04-05 ZX-10 Engine Predator ZX-10 Wanted: Buy or Trade 1 06-27-2010 10:53 PM
Engine Ice Vio Vendor Deals 2 03-23-2010 09:52 AM
'06 engine dsabat Parts, Gear and Accessories 7 12-02-2009 12:03 PM
Best way to clean a rashed engine cover engine? Suzuk1ki11a Performance and Tech 4 06-06-2007 02:38 PM
zx-10 case markings Vince10R Performance and Tech 4 05-11-2007 01:53 PM
