Engine Knock after crash - Kawasaki ZX-10R.net
post #1 of 10 Old 11-07-2014, 10:08 AM Thread Starter
Omofo's Avatar
Lowsided into a curb, shattering the oil pan. The bike ran for about 5 seconds before it cut off. I got it back together last night, and now I hear a knocking sound I don't remember before, coming from the right side cylinder/ starter area. Possible engine damage?
Ignorance is the enemy, let's set the record straight. If history must repeat itself, why worry while you wait?- Rodney Crowell
Omofo is offline
post #2 of 10 Old 11-07-2014, 10:16 AM
SkyDork's Avatar
Yeah, possible engine damage from the sounds of it. The knocking sound could be a spun rod bearing if the engine was running without oil pressure. But it could also be something more mechanical if any of the engine covers were damaged/bent as well.
Sorry to hear of your accident.
#WordCrimes
SkyDork is offline
post #3 of 10 Old 11-07-2014, 10:19 AM
Speed-racer's Avatar
Thought it would have stopped running instantly with tip over switch? Maybe there's a delay in it.
It's not that I don't want to ride with you, but you ride too damn slow.
Speed-racer is offline
post #4 of 10 Old 11-07-2014, 11:24 AM Thread Starter
Omofo's Avatar
Had to replace the stator cover, the starter cover is gouged but holding oil. The throttle tube also got smashed, causing the motor to rev up as it spun around on the stator cover.
Omofo is offline
post #5 of 10 Old 11-07-2014, 11:31 AM
SkyDork's Avatar
Confused. The stator is on the left side of the motor. The starter is on the right, along with the throttle. What side did the bike fall on? Why replace the stator cover?
#WordCrimes
SkyDork is offline
post #6 of 10 Old 11-07-2014, 11:33 AM Thread Starter
Omofo's Avatar
Lowsided on the clutch side, when the bike hit the curb it flipped over.
Omofo is offline
post #7 of 10 Old 11-07-2014, 11:34 AM Thread Starter
Omofo's Avatar
I'll post a video of the noise when I get home.
Omofo is offline
post #8 of 10 Old 11-07-2014, 12:06 PM
SkyDork's Avatar
Ouch. Yeah, if the throttle got pinned open and revved the motor after the pan split, sounds like the oil pressure dropped and the motor has probably spun a rod bearing as a result. The knocking you're hearing is likely the crankshaft beating the journal flat from the lack of oil. But that's just an internet guess at this point.
#WordCrimes
SkyDork is offline
post #9 of 10 Old 11-07-2014, 03:03 PM Thread Starter
Omofo's Avatar
Looks like I'm due for a rebuild, or ebay motor.
Omofo is offline
post #10 of 10 Old 11-07-2014, 08:31 PM
blink.'s Avatar
Had a friend have almost the same kinda crash on a yzf 600r, it was knocking from a bent crankshaft, motor was toast.
blink. is offline
Gen 2: Octane knock? rod knock??? TexasRider Performance and Tech 9 06-23-2012 05:42 PM
Gen 1: Engine knock? Bad??? spirity Performance and Tech 12 06-05-2012 10:55 AM
Gen 1: Engine knock ninja10kid The ZX-10R 5 01-09-2012 03:37 PM
2005 engine replacement after crash NorCal05ZX10R The ZX-10R 0 04-23-2008 09:24 AM
Engine knock at low RPM's? morefire Performance and Tech 10 04-06-2008 09:24 PM
