Engine Ice or Water Wetter? - Kawasaki ZX-10R.net
post #1 of 12 Old 01-09-2005, 05:21 AM Thread Starter
Hi guys
I live in a hot country and would like to know from u guys which is the more preferable coolant for me.
My country don't have 4 seasons here.Through out the year is summer.
If using water wetter what is the correct ratio to mix?
How much of the water wetter is needed for the zx-10r radiator?
Anyone using Motul Inugel Expert here?
http://www.motul.com.au/product_lin...ugel_expert.jpg
Peace.
kwakzx10r is offline
post #2 of 12 Old 01-09-2005, 08:30 AM
I am no expert since I just started using both these products last summer. The Water Wetter seems to be a better and cheaper option for you if you don't have to worry about cold/freezing weather. It costs less, accepted at tracks and is a simple 50/50 mix. Engine Ice is pricey but protects from freezing. Engine Ice is not mixed at all, it replaces the coolant/water mix 100%.
Green ZX10, Scotts Dampener, Muzzy Ti, Power Commander, braided lines.
steves87 is offline
post #3 of 12 Old 01-09-2005, 08:44 AM
Supercharged Mod
If you are not doing track days I would stick with standard coolant/water mixture. It not only lowers the freezing point but also raises the boiling point.
I've found that standard green coolant will lead to deposits in the cooling system over time, but Volkswagen G12 coolant will not (phosphate-free and without the problems of Dexcool). I switched mine over to that. If you switch it, you must *completely* flush the system, because this stuff is not compatible with the standard green stuff. Available at any VW dealer.
If you ARE doing track days or racing, you'll have to check the rulebook of whoever is organizing them. Water mixed with WaterWetter is accepted everywhere that I know of, but Engine Ice may not be.
GoFaster is offline
post #4 of 12 Old 01-09-2005, 08:47 AM
Supercharged Mod
Whoa, hold it! Water Wetter does not get mixed 50% with distilled water. The mix ratio is quite low, a few milliliters per litre in the cooling system, and there's about 2-and-change litres in the cooling system of these bikes. The correct mix ratio is on the bottle ...
GoFaster is offline
post #5 of 12 Old 01-09-2005, 08:50 AM
magzx12r's Avatar
You add water wetter to your coolant/water mix: 4 cap fulls per quart. I went a little above that and added ~ half a bottle to my coolant/water mix on my previous bike. For racing, you mix the water wetter with distilled water only.
When I put engine ice in my ZX-12R, it seemed to run a little cooler. When it is time to replace the coolant/water in my ZX-10R, I will replace it with engine ice.
Unless it is time to change out your coolant, I would try adding some water wetter to your current coolant to see if it helps enough.
Mark
magzx12r is offline
post #6 of 12 Old 01-09-2005, 11:14 AM
You can run watter wetter and just water. They have a mix ratio if you are running just straigh water and the wetter
Frankyoz is offline
post #7 of 12 Old 01-09-2005, 12:25 PM
Andy's Avatar
Images: 25
moved to tech
Andy is offline
post #8 of 12 Old 01-09-2005, 01:30 PM
Waterwetter is fine for track use but it doesn't protect from corrosion. So it your doing more street riding than track day go with the Engine Ice.
grnblur is offline
post #9 of 12 Old 01-09-2005, 07:26 PM
According to the back of the bottle it, "provides excellent engine corrosion protection for modern cast iron, aluminum, and brass systems." It does recommend running 15% antifreeze in street vehicles.
Frankyoz is offline
post #10 of 12 Old 01-09-2005, 09:16 PM
I know what it says ive just seen engines torn apart that was run with distilled water and water wetter. There was a decent amount of corrosion in the head.
grnblur is offline
How to replace water wetter w/antifreeze? steves87 Performance and Tech 12 02-17-2007 11:41 AM
Engine Ice or water wetter? kwakzx10r Performance and Tech 0 01-08-2005 09:33 PM
Any downside to using Engine Ice? steves87 Performance and Tech 2 11-01-2004 09:07 PM
Water Wetter mods2come The ZX-10R 3 06-28-2004 01:59 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
