Engine ice ? - Kawasaki ZX-10R.net
post #1 of 15 Old 06-07-2010, 08:33 PM Thread Starter
M109R's Avatar
Engine ice ?
I just talked with a guy that said that you can mix the engine ice with the coolant that is in the bike. I just want to check with everyone else to see if it is true. I had it in my Busa but i drained the whole system and just used the engine ice.
M109R is offline
post #2 of 15 Old 06-07-2010, 10:15 PM
flthy1's Avatar
Not sure of the answer but if your bike is low on fluid why not just drain it, flush it and refill it with ice? Pretty easy job to do
flthy1 is offline
post #3 of 15 Old 06-07-2010, 10:19 PM
foster_pv's Avatar
Send a message via AIM to foster_pv
i thought you were suppose to mix that with distilled water?
foster_pv is offline
post #4 of 15 Old 06-07-2010, 10:28 PM
flthy1's Avatar
No, engine ice is not a solution you need to mix with water
flthy1 is offline
post #5 of 15 Old 06-07-2010, 11:27 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
DO NOT add it to what's in your radiator already (unless there's engine ice in there already).....the directions VERY clearly state to drain and flush all the old coolant out before putting it in. i've had buddies do a half ass job of draining and they just added the ice......bikes started running hotter than normal. i think it's like $30-$40 per container and it usually takes about 2 of them sooooooo i'd take the time and do it as directed. just my
TMY10ER is offline
post #6 of 15 Old 06-07-2010, 11:35 PM
flthy1's Avatar
Keep lookin if you see this price! I got mine at a local shop thats generally high priced and mine was 18 something per container!!! Just saying
flthy1 is offline
post #7 of 15 Old 06-08-2010, 12:52 AM
ZX10BURNER's Avatar
Send a message via Yahoo to ZX10BURNER
For your questions concerning Engine Ice http://www.engineice.cc/faq.html
It's Not denial, I'm just very selective about the reality I accept.
ZX10BURNER is offline
post #8 of 15 Old 06-08-2010, 08:49 PM Thread Starter
M109R's Avatar
Thanks for the info on that. I never even thought of checking there web site
M109R is offline
post #9 of 15 Old 06-08-2010, 09:15 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
Use de ionized water...Not shure if thats the same as distilled or not but my 10 worked great with de ionized water and water wetter..
I keep wanting to look into the evans coolant but usually forget 10 seconds later...Must be gettin scatter brained....HHHMMM now what was it we were talkin about??? lol
craig_sez is offline
post #10 of 15 Old 06-08-2010, 09:21 PM
flthy1's Avatar
Whats up man?!?!?! Hows that gen 3?!?!? ^^^Sorry for the temp thread jack!!!
flthy1 is offline
Engine Ice Vio Vendors deals 2 03-23-2010 08:52 AM
engine ice wicked General Motorcycle Discussions 32 06-27-2008 06:38 PM
Engine Ice...will it last the winter? Jay Performance and Tech 7 11-05-2006 12:39 AM
Any downside to using Engine Ice? steves87 Performance and Tech 2 11-01-2004 09:07 PM
engine ice. alley cat The ZX-10R 7 04-27-2004 11:18 AM
